Who would have thought anyone with one of the gearboxes would say this, but I don't have to touch my synchros--they are beautiful and OEM, not the least because I almost always double clutch, so they don't see much use
It's also been less than 20,000 miles since I went through the gearbox. I had a couple of fully assembled input shafts and went with the prettiest one without thinking about mileage on the bearings when last I buttoned it up.
Whoops.
I also haven't found a solution for getting the shim preload right, other than more patience than I've got. All the places that still sell the shims don't sell all of them and, further, only sell them in packs of 10, so I'll end up spending $50 or more, with shipping, to likely get just the sizes I
don't need--in packs of 10.
Why couldn't they just make really thin ones so you could get a bunch and always get it right?
Two interesting things I noticed when I tore down the box again:
Perhaps a symptom of incorrect preload again, as the output shaft seemed to have "settled" such that the shims I put in were no longer correct, I found that the screws holding the plate in were barely hanging in there. Given that the heads are all buggered up anyway, I plan to use socket-head screws and red loctite so I don't have to worry about them working themselves loose. I'll post up s picture and share my source when the new screws show up, if they fit.
I also noticed that the large bearing on the input shaft looks fine, but seems to have lost it's press fit onto the shaft and can slide off without effort. I don't yet have a replacement to check whether the bearing is too big or the shaft too small. Does it matter? I. E. it's not going anywhere even if it doesn't need to be pressed on the shaft (I don't think) should I worry about this?
Hoping this will be the last time I have to take the box apart for a while, knowing this is true only if one's definition of "a while" is pretty loose
