It is currently Fri Nov 24, 2017 9:57 am
PostPosted: Thu Sep 15, 2005 12:17 am
Moderator & FAQ King
Manual Transmission:
Factory Service Manual sections:
MK1 manual transaxle (includes T3 info):
http://www.teamswift.net/viewtopic.php?f=9&t=26290
MK2/MK3 manual transaxle:
http://www.teamswift.net/viewtopic.php?f=9&t=14856
Transmission Removal MK2/3 (includes bolt sizes & torque specs):
http://www.teamswift.net/viewtopic.php?p=82299#82299
Transmission Removal MK4/5 (includes pics)
http://www.teamswift.net/viewtopic.php?f=2&t=38129
Transmission Rebuild MK4/5
http://teamswift.net/viewtopic.php?f=9&t=50486
Transmission Installation:
http://www.teamswift.net/viewtopic.php?t=14697
DIY MK1 Transmission Repair (splitting the case):
http://www.teamswift.net/viewtopic.php?f=9&t=42589
Alternate Gear Oil Fill Location:
http://www.teamswift.net/viewtopic.php?t=11004
Short Shifter Info:
http://www.teamswift.net/viewtopic.php?t=2119
http://www.teamswift.net/viewtopic.php?t=3498
http://www.teamswift.net/viewtopic.php?t=3609
http://www.teamswift.net/viewtopic.php?t=3646
http://www.teamswift.net/viewtopic.php?t=11347
Shifter housing bushing delete:
http://www.teamswift.net/viewtopic.php?t=36184
Misc:
GTi driveshaft spline compatiblility
Transmission carnage (post pics of your dead tranny)
Gear Ratios:
All Swift gear ratios:
http://www.teamswift.net/viewtopic.php?f=9&t=31702
Finding ratio by code:
http://www.teamswift.net/viewtopic.php?f=9&t=18163
Limited Slip Differentials:
http://www.teamswift.net/viewtopic.php?f=9&t=2209
Clutch recommendations:
http://www.teamswift.net/viewtopic.php?f=9&t=2218
Automatic Transmission Info:
Automatic Transmission Troubleshooting Guide
http://www.teamswift.net/viewtopic.php?f=9&t=35213
( miracle pour hole)
maybe a picture Thanks
PostPosted: Fri Apr 02, 2010 1:03 pm
Finding ratio without 'code':
Put the car in 5th, lift one front tire off the ground and rotate the crankshaft.
Rule #1:
For a 3.52 gear ratio: 4 crank revs = 3 tire revs. (74 ring/ 21 pinion teeth=3.5238095)
Rule #2:
For a 3.79 gear ratio: 3 crank revs = 2 tire revs. (72 ring/19 pinion teeth= 3.7894736)
PostPosted: Fri May 07, 2010 11:55 am
Rule #1:
Rule #2:
Let See The Video.!
PostPosted: Thu Apr 04, 2013 4:28 am
I can't provide a video, but I can provide some pictures.
Here's the thread
http://geometroforum.com/single/?p=439157&t=4187023
and Wobblybob gives me credit in his first post (thanks for that).
Here you go:
4.39
4.10
3.79:
3.52
There are many threads outlining how to count teeth to determine the ratio and we should thank Lihtan and Dattman for their contributions.
PostPosted: Thu Apr 04, 2013 4:31 am
:werd:
That's a great post.
PostPosted: Thu Apr 04, 2013 6:04 pm
that method makes a junkyard selection fast and easy. :wink:
thanks phil.
PostPosted: Sat Jul 13, 2013 2:36 pm
Finding the ratio made easy with those pictures. Well done @Phil N Ed. :)
Transmission Checking @ Plano
Users browsing this forum: Google [Bot] and 4 guests
