Okay, I know the topic has been somewhat covered before but I’d need some clear answers from people with experience.
I’m looking to supercharge my swift
(2001 3cyl 1.0 TBI) I already have the supercharger (AMR300), But I just simply don’t want to start doing anything until somebody with reasonable knowledge reassures me that the stock fuel system can take 5 PSI, I’m running all stock internals stock everything. so far what I have read on the topic is that the stock engine can take 5 psi no problems, I’m just unsure if I have to do anything with the fuel system? Of course I’m trying to avoid any detonation, so higher octane fuel and retarded timing has to happen.
So my questions would be:
- Would the ECU be capable to deal with boost and adjust the fuelling map accordingly?
- Do I need to do anything at 5 psi so the engine gets enough fuel?
- I know I have to retard the base timing manually (it’s quite advanced as of now) any advice on how much retarding it needs?
- Blow through setup or no? (from what I know the injector spraying into the supercharger is good for cooling it, probably not so good for throttle response and fuel delivery as the injector would be very far from the actual intake. I’m just trying to think logically here)
- would I need the CTS mod?
- What’s the injector flow rate for the 1.0?
Of course I’ll take any advice from people with previous, supercharging/turbo experience. I’m on a very limited budget, so apart from the supercharger I’m getting a Wideband sensor and a boost gauge so just the necessities for monitoring (potential death
) of the engine
