i'm using the ms2 ver 3.0 controller modified with a jbperf 4 channel injection/ ignition driver board populated with 3 channels.
i de-populated the main board of many components that weren't needed with the jbperf mod including the crystal oscillator. the processor uses the crank trigger wheel count instead of the oscillator to clock data through the register which makes the processor run with great stability. it also allows the controller to operate the predictive mode with better accuracy.
i developed a hall effect device sensor set for the crank and cam angle counts using little chinese hall effect device signal processor boards that output a zero to 4.56 vdc amplitude square wave at any frequency, tested to be rock solid up to 10,200 rpm, and then depopulated the signal conditioning components from the megasquirt's main board. i connected the hed signal conditioning boards' outputs directly to the processor on the daughter board landing the wires onto little solder pads.
i also removed the injection and ignition drivers from the hear sink on the controller board to cut down on heat inside the enclosure.
i'm running the latest msextra firmware and run the latest version of a licensed version of tuner studio.
i use the mosfet ignition drivers on the jbperf board to switch 3 hitachi ignitors from a gt dohc and run 3 cop coils from a ford v8 on each spark plug. the injector drivers on the jbperf board drive the 3 lo-z 450cc/min injectors directly.
it took a little work to set the dwell on the ignition circuit to keep the cop coils from heating up but that configuration renders super throttle response. there's nothing but go, go, go when i stomp the gas pedal.
as a matter of fact, i have to use the throttle judiciously or the drive tires just roast, even in third gear.
