Okay - a rundown of the whats going to be done to the car:
Engine:
-3Tech cylinder head package, including:
10.7:1 compression ratio
Swirl polished stainless valves
10DEG advance sprocket
218/350 cam regrind
Delete TBI bridge (once the car is done, I'll start working on a ITB setup w/ megasquirt or Performance Electronics stand alone ECU)
Delete resonator
-Rebuilt bottom end, including:
0.5mm overbore, 0.010" decking, full blueprint
crank magnafluxed & polished
JCC pistons
NPR rings
Full build-up by H-R&D engine specialist
Piston oil squirters added to oil main galley
Underdrive Aluminum pulley
Braille lightweight battery
G13 flywheel w/ Exedy clutch kit
(for engine/clutch/transmission: all seals, linkages, bushings, cables, etc. replaced with new OEM parts)
Suspension:
New FR & RR control arms, tie rods, toe links, ball joints
H&R springs
KYB GR2 struts
replacement KYB strut mounts
GTi FR & RR stabi bar (addco RR stabi bar eventually)
GTi Steering rack
Momo 12" steering wheel
Whiteline suspension bushings
ADAMS suspension simulation (everything I'm doing is tried & tested, but I want to have a baseline understanding incase I have problems auto-x, and I need to modify/adjust something in the future)
13x5.5 38mm offset Ultralite 8-spoke wheels
175/50-R13 Sumitomo HTR200 tires
Brakes:
Custom PF compound FR pads (running with stock calipers and Brembo rotors)
Goodrich braided stainless brake lines (replaced RR outboard banjo fitting with compression/flare fitting to suit RR drums)
Body:
Fix the damn rust!! replace RR corners, fix seatbelt anchor brace & floor, replace driver's side floor section & rocker section, POR-15 everything
Murr lower FR x-brace
RR strut tower brace
Delete spare tire & jack
Delete floor & trunk melt sheet
Delete firewall insulation & melt sheet
Delete rear seats
Delete many other small items!
Interior:
Gti FR seats (eventually lightweight Aluminum race seats)
I'll list more items as they come to me... some stuff I haven't decided on yet.
Currently the car is stripped down, engine torn down.
Head is at 3-Tech, block, oversize pistons and crank are at engine builders.
I'm in the middle of fixing the rust, hopefully getting the paint on the floor and underside before winter.
Some pics:
How the car looks currently:
Firewall/frame rails, etc. pretty much rust free:
Close-up of passenger side control arm pick-ups:
Stripped interior:
Melt sheet removed:
Rust in floor cut out (this area is now all back together - have to take new pics)
RR suspension pick-ups (also mostly rust free around here)
Seatbelt anchor with rusty area cut out, sandblasted, patch TIG welded in:
I'll take new pics this week and update the rust repair progress...
