blueturbofly wrote:
its a little more involved than just a ecm&powertrain swap;tranny mounts are way different,auto cars dont have standard tranny mounts,let alone going from a 3cyl to a 4cyl;driveshafts are different again,being equal length&larger diameter on the swift,wont fit convert knuckles/bearings.
remove ENTIRE front suspension from gt,unless you just want knuckles.it can be swapped,dont worry;just need time tomake sure you remove EVERYTHING from donor car,and that may include cutting off some mounts for the swap,wiring harness
i bought a smashed 5 door pontiac firefly auto that someone converted into a turbo 5-speed.at first i thought they just dropped a factory turbo motor in the car but the person that did the job ALSO changed it from auto to stick shift.cut all the mounts from the turbo car,mig welded them into the 5-door.they did a really good job,looked like factory.
dont worry,it can be done!oh,is it a gt or gti?GOOD LUCK!
Thanks for the info, and I'll take all I can get on this one. I'm way out of my comfort level on this one. If you've read through the thread you've heard me repeat
"I am no mechanic", just cheap and stubborn
. I believe you're correct in that the best bet is to just drop everything from the GT donor and put it into the vert. I'm just really going to miss the auto is all...
. It's to bad there's not a way to make it work with the 1.3L... I wonder if there is a good auto made for the 1.3L?
Not sure if its the gt or gti (it is a 1990 for the Canadian market if that helps) but now I'm curious if there is a difference?
Smashed eh... I can empathise. I originally built this for my girlfriend. Now that I've put all of this work into it, and cognzant of how she treats her vehicles, I kind of don't want to give it to her as it'll just get destroyed,; either slowly by neglect or by her driving habits. And then I'd go to jail, and I don't want ot go to jail
Decisions... decisions...
90 Chevy Sprint 'Vert Mk2 powered by a 1.3L DOHC and 2 rabid gerbils
'Noisy Cricket' build thread http://www.teamswift.net/viewtopic.php?f=36&t=46988
