It is currently Thu Nov 23, 2017 3:59 pm
PostPosted: Thu Aug 10, 2017 9:59 pm
my starter is going and I need an replacement. I've check rockauto but the listing is kinda confusing
ACDELCO 3361524 -
Firefly turbo - Permanent Magnet Gear Reduction; Unit Mfr: Mitsubishi; kW Rating 1.4; Permanent Magnet Gear Reduction; w/ Permanent Magnet Gear Reduction
Sprint turbo - Automatic trans.; Permanent Magnet Gear Reduction; Unit Mfr: Mitsubishi; kW Rating 1.4; Permanent Magnet Gear Reduction
ACDELCO 3361555 -
Direct Drive; Unit Mfr: Mitsubishi/ND; kW Rating 0.8; Direct Drive; w/ Direct Drive
can someone tell me which one is the right one?
1992 Geo Metro Convertible (with mk2 g10t)
PostPosted: Fri Aug 11, 2017 8:02 am
any of those will work.
i prefer the high torque gear reduction starters. :wink:
PostPosted: Fri Aug 11, 2017 7:39 pm
thanks for the reply, I will order the high torque one then :thumbsup:
PostPosted: Sat Aug 12, 2017 9:09 am
i find my high torque starters under listings for the mk1 cars or specifically for the 89 automatic vert. :wink:
cron
