I recently swapped over the drivetrain from my 91 turbo firefly (Non existent body) into a rust free 90 sprint.
before taking the car out for a drive I decided to install one of the 3tech camshafts.
after getting the timing where I thought it was right, I was able to take it out and let it fly in 2nd gear.. and I was VERY impressed with the power. Judging by the boost gauge the car was making somewhere around 8psi. I turned around to come back home and gave it some steam in first gear, it immediately shutdown (some sort of fuel cut around 6k) and proceeded to have no power. I assumed something was amiss with the coldside piping maybe, but I babied it home, as it idled I looked and looked for an issue with none to be found.
I came back a few hours later, started the car and heard a rattle.. long story short I figured out the turbine had separated from the compressor in the turbo. (PS the car has a well operating slightly crushed DSM bov to avoid compressor surge)
If I had to guess I'd bet I've only put around 20KM on this little motor, I have absolutely no idea as to what caused the shaft to snap.. But here are my quick questions that I hope somebody can help me with, PS thanks for taking your time to read my wall of text! I've searched and searched but every question seems to have 2 totally different answers.
#1) How different are the RHB31 and the RHB32 turbos? Is the only difference the exhaust housing? I have found a new shaft and turbine for less than $100 dollars for the rhb31, is this a direct replacement for the rhb32? What is my best option to fixing this turbo, or replacing it?
#2) How does one avoid what seemed to be a very harsh fuel cut which likely was the cause of the broken turbo shaft? I do not plan on cranking the boost. The camshaft was put in to avoid having to turn it up and put a stress on the little turbo.. well that didn't work very well. Is there something inside of the VAF that can be modified with no ill effects which causes no power cut?
Thanks again everyone.
PS. I have a little Mitsubishi turbo that when not compared to the original turbo seemed usable, but now that I have them both sitting on the bench here.. I'm not sure the little 3 banger would ever spool it.
1991 Turbo Sprint! & a dirty old turbo ls1 Camaro
