i spent several hours sand blasting parts to prep them for powder coating. i had soaked the oil pan in a solvent tank for 3 days and then gave it a scrub with alconox to get all the grease and oil off before media blasting it.
i decided to do a new fuel rail in satin black ceramic to accent the chromed banjo fittings. the red and silver one is pretty but the satin black will keep things from getting to busy in the color scheme. it's done and on the mock up. i'm still waiting on the 9 chrome bits (and scrounging up the money to pay for them.)
i bought a set of silicone radiator hoses in blue, the $29 ones on ebay. they came today and look good, 25mm and good for 5 bar pressures at 180* f. phil n ed hooked me up with a twincam coolant pipe set so i can route the coolant lines to leave room for the liquid to air intercooler in the space over the tranny. i also found a fabricated aluminum engine coolant radiator and low profile fan that allows the proper clearance for my charge air piping and another radiator and fan for the intercooler that's being built now.
i figure that i'm about halfway to having all the parts for the project collected. i still have most of the assembly work to go, though. i've gone to the fastener supply counter so many times now that i take the guy a coffee. everytime i get $5 in my pocket, i buy a handfull of stainless steel bolts.
the big ones, like for the engine mounting arms, are $8 a pop! it'll take me all winter just to buy all the nuts and bolts.
i've started another task. i'm cutting tin to build my belt guard. i'll do it in galvanized steel to get all the dimensions and bends just right before i start working with stainless. i might have to get a sheet metal shop to do the bends on the standoffs when i build the real one, i don't have a sheet metal break with enough poop to make nice bends on stainless. to do it right, i have to have a machine that will radius the bends on the heavier gauge and stainless steel alloy with enough nickel and chrome in it to be reasonably called "stainless" can be pretty brittle. it cracks when you break it too sharply. i also don't have access to a roller to do the curve at the top of the guard.
my original design used slots, sort of skeletonizing the basic shape, which will probably have to be dropped due to expense. it's along the same lines as an open primary cover on a custom belt drive chopper.
until my next progress report.
