I need to modify the intake cam sprocket for my DOHC engine. I want 4 degrees advance on the intake valves.
My question is are the SOHC 16 valve and the DOHC 16 valve use the same cam sprocket?
The DOHC cam gears are round cut, the SOHC cam gear is square cut.
So I did this mod to my DOHC intake cam gear.
The rotory table allowed me to use the factory cuts as Zero for the new positions that will be at 4 and 6 degrees advanced.
On the cam gear it will actually be 2 degrees and 3 degrees.
I had to order a 5 mm carbide end mill to do the new cuts.
3631 shows centering the cam gear on the rotory table then centering the rotory table to the spindle.
3635 is showing the the alignment tube that helped center the gear. The tube is in a collet in the rotory table.
I used a tube instead of a solid piece. The tube is a sacrificial part that will be cut into when making the new slots.
3638 shows the 4 degree slot cut. The rotory table makes this easy. Once the original slot cuts are zeroed,
I can rotate the rotory table by degrees, minutes, and seconds to the new slot location with the proper 2 degree off set,
lock the table down and make the cut.
3639 is showing the cam gear cut for both 4 and 6 degrees. the shiney spots on the gear are where I stamped the cam
gear with numbers of degrees advance.
A quick road test with the intake gear set at 4 degrees shows signs of improvement in the lower RPM ranges.
Why pay $100 for something I can make in less then 30 minutes?
I would like to do a set at 8 and 10 degrees, but I need another set of DOHC cam gears.
If you have an extra set that you are willing to part with, I will cut you a set of cam gears with 2 offsets of
your choice for free in exchange for the DOHC gears I need.
