Thank you everyone who has sent me a distributor to build. I rebuild distributors for TeamSwift members. This service is offered on distributors that you send me.
ODB1 and ODB2 distributors. New main shaft Class 3 bearing, directional seal, outer body o ring, glass bead housing, reset airgap, replace screws as needed. Air gap set on pickup coil. $40 + $10 shipping. Electronics are checked, and replaced at additional cost if needed.
Pre ODB1 distributors These have vacuum advance, and mechanical advance. 90% of these are rebuildable. The time it takes to do these drives the cost up. New main shaft class 3 bearing, seal, outer o ring, advance springs, free up vacuum advance plate bearing. Glass bead housing, replace screws as needed, cap clips, outer screws, are de-rusted and parkerized to prevent further decay of the parts. Dark gray color on the parkerized parts. I will recurve the mechanical advance because of the springs being replaced. Air gap set on pickup. $90 + $10 shipping Electronics are checked. If the electronics are bad I will replace them at an additional cost. Vacuum advance units are checked. If they are bad I can replace them at an addtional cost
Warrenty is for one year on workmanship and replaced parts. I do not warrenty bad installations. PM me for shipping information, and turn around times.
_________________ Fainya 97 Geo Metro LSI,1.3L-GT-DOHC-16v,4.10 5-speed,A/C,170,000,suspension lowered 1",4 wheel disk brakes,15"alloy wheels with 185/50-15 Toyo's,GT bucket seats,analog oil pressure gauge,cruise control, new paint job. 40 mpg at 65 mph. Good, fast, cheap. You only get two.
