that is crazy talk
that like saying....  It's ok to reuse your stretch type head bolt more then once
you make a good point...... Being the age of our cars  that idler pulley should be changed at least once and inspected every T-belt change
 you  should also change the oil on a regular bases.
 But a lot of people driving are cars don't think long term like you and I
You know these car were the bottom of the food chain (cheep transpo) .
A Between 'r
A throw away as you will car
not looked upon as long term Vehicles when they were first produced
We've all seen the video were after a few year's people would cut the tops off and let the "Kid's" drive them around the yard Like a Go-kart
Our cars GOT "No Respect"
Hell the Third gen's a lot not all had piston to rod bearing clearances within the first 20,000 miles
parts were expensive back in the day
 I'm talking $200 for an Alternator back in the  early 90's for a car that was 5-8 yrs old.?
Sometimes in extreme cases timing belt replacement is not needed
Getting back to topic.......
I believe this method  would work .
and yes
 Changing the belt is not that big of a job. yet still alot of post in the past inquiring about Timing marks and
 T-Belt alignment
I would be lieing to you if I told you that every time I change the timing belt I change the Idler pulley assmbly
It just doesn't happen every time..... but I always chnge my oil religiously
 and always use a synthetic blend in my turbo cars
 also Marvel Mystery oil in every combustion type engine I owne
That's a fact
 No bull
 You can take that to the bank
....................................................jv&s
