Ok so I have a stock GTi gearbox laying around and when I see through the hole where the driveshafts go into, I see 1 bar going across. This is an open diff. (Stock)
Now, the currently installed gearbox in my turboed GTi I remember seeing through the hole and seeing 2 bars (or 2 pins) across each other. Like a "cross" if you know what I mean. The guy I bought it from told me it was a GTi gearbox he brought back from the Netherlands with lsd installed in it. I'm certain it is a gti box as it has the extra hole for the brace to the block. But what about the 2 bars crossing each other?
_________________ 1991-GTi: JE 75mm 11:1 pistons,Ported head, Single UD pulley (OCC),Sandros chip,Aluminium flywheel,3tech 222/365 cams, Cultus headers,Cultus IM,50mm tb,Crane cams adjustable cam gears,Apex suspension, 4.39fd GB. 1989-GTi: 3Tech 210/340 Cams,Cultus IM, B&G springs, TD04L turbo, Apexi SAFC, Suzukird UD pulley, Circuitse7en dual boost controller, AEM wideband, AEM water / meth injection kit, HKS bov. 2001-Altezza AS200: Stock.-sold 2003-EVO7 GT-A Aruba "one happy island".
