It is currently Fri Nov 24, 2017 10:30 am
 Post subject: Auto trans acting odd
PostPosted: Thu Jun 30, 2016 5:48 pm
I've not been on here in years , still watch from the side lines
Have a 1992 vert , has only high gear . Both solenoids check good.
I can put voltage on each and it will shift manually . When I plug
Connector back in it will shift auto once then go back to high only .
Unplug the connector and fire each solenoid once and will shift manually
Again ?
Thanks
PostPosted: Sat Jul 02, 2016 4:39 am
Usually bad capacitors inside the TCM.
PostPosted: Sat Jul 02, 2016 9:46 am
Them look ok ,no leakage.
PostPosted: Sat Jul 16, 2016 3:56 pm
Shift down cable not adjusted properly.?
