Hey, guys. Love this forum. I have a couple of questions about swapping in the Aerio trans into a Mk3. I know from reading threads here that I need...
To adapt trans for cable clutch and figure out a speedometer solution.
To use 1.6 GLX drive axles and Swift Gt hubs.
Can I rebuild the outer cv joints so that I can use them with the 23-spline hubs?
Also, I have the driver side trans mount, and the rear mount from a Swift Gt. Will these mounts work with the Aerio trans?
bostssgt never mentioned in his swap thread what he used to mount the transmission he swapped in, so I am not sure.
Thank you for the cool forum.
