It is currently Fri Nov 24, 2017 10:25 am
Post new topic Reply to topic  [ 6 posts ]
PostPosted: Sat Sep 05, 2015 12:05 am
Folks, going to be doing a transmission build, and got the rebuild kit.
Does anyone know how to identify which synchro is for 1st vs 2nd? They look fairly similar, but I can't tell if they're quite identical.
Ofensus Racing
Rally Racing Geo Metro
PostPosted: Sat Sep 05, 2015 4:35 am
The kits are shipped with identical syncro's these days, originally first gear has a keyslot of 8.2mm/0.32 and 2nd has a 9.6mm/0.38 wide keyslot.
I'm sneaking a photo in here since photobucket has turned to custard.
Please don't comment on this thread.
PostPosted: Sat Sep 05, 2015 4:40 am
hungary made "SGP" synhros are all 8.7mm
PostPosted: Sat Sep 05, 2015 1:26 pm
Thanks folks!
Ofensus Racing
PostPosted: Thu Sep 10, 2015 1:40 am
If you want to apply just a bit more braking power to the 1/2 brass. You can use the springs from a T5 trans. Its a thicker gauge spring. They are just a bit longer. But you can trim them to size with a good set of dikes. It works great. It does wear them out just a bit faster, but your racing and don't want to get 100k miles out of them.
PostPosted: Mon Sep 19, 2016 6:03 pm
I just rebuilt a GT box using the Anaheim Gear bearing and seal kit which was all good Japanese bearings. But the Synchro kit I got separately from Ebay (different vendor) had identical 1 and 2 synchros. Within 20 shifts it was already grinding 2nd gear!
I had to pull the box, split it and press the counter shaft apart. I reused old 1 and 2 synchros from a low mileage JDM box and it works great now.
I STRONGLY urge people to try to find the correct 2nd gear synchro, unless you need the rebuilding practice.
cron
