It is currently Tue Nov 21, 2017 8:01 pm
Post new topic Reply to topic  [ 6 posts ]
PostPosted: Tue Oct 10, 2017 1:36 pm
Hi to all,
Does anyone knows how much we need to spend to go RWD on our Swifts?
Thanks
1992 MK3 Euro Swift GTI, Suzukird SS Exhaust header + freeflow SS exhaust + N1 Tip, Suzukird aluminum fuel rail + FPR, 60mm Nissan 200SX TB + K&N Air Filter, Reinforced OEM Clutch + Suzukird Short Shift + Aluminium Flywheel + Gripper 1.5 way LSD 30/70, Apex springs + Koni Sport Shock Absorvers + Wiechers Sport Upper Front Strut Bar + Upper RearStrut Bar + Below Front Strut Bar, Suzukird Underdrive Pulley, 15"x7" Antera Wheels + Bridgestone S03 195/50R15, Kevlar pads + SS Sloted rotors + SS hose kit
PostPosted: Wed Oct 11, 2017 2:37 am
That depends on your fabrication skills and how well your garage is equipped.
Personally I think its easier to go AWD especially since you are in Europe . Just get early 2000's Suzuki Swift AWD sold as Subaru Justy in Europe and drop in G13B , turbo it and you get real pocket rocket
PostPosted: Wed Oct 11, 2017 9:51 am
Great info thanks a lot!
But personally I would prefer to adapt the mechanics from Suzuki Swift 1.6 16V 4x4 Sedan or Subaru Justy 1.3 4x4 on mine Suzuki Swift GTI, is it possible (is always bolt on - since fabrication is none around here)?
Secondly where I can buy LSD for Suzuki Swift 1.6 16V 4x4 Sedan or Subaru Justy 1.3 4x4 in Europe?
Does the transmission is compatible in any way with G13B (I have a Gripper LSD can I reuse it)?
Regards,
Miguel
PostPosted: Wed Oct 11, 2017 11:07 am
4x4 Swifts have different rear part of the floor pan . You would have to cut the floor pan out of yours because AWD models have rear sub frame that bolts to almost flat floor pan
There is company in Hungary that makes LSD for 1.3 and 1.6
AWD box is compatible , bolts right up
Do the search , there was plenty of discussions on this forum about things you are asking
PostPosted: Wed Oct 11, 2017 4:26 pm
Thank you a lot... Great info... by the way I have found someone tried to convert swift sedan 4x4 to hatch but I am afraid it wasnt sucessful http://myweb.tiscali.co.uk/madzuki/twinc4x4conv.html
Does anyone knows where to find a cheap and fair justy 4x4 in europe?
PostPosted: Fri Oct 13, 2017 12:04 pm
http://www.mobile.de
AWD Swift was sold as AWD Justy from 1996 till 2003 in EU
