I'm in a bit of a pickle and need to tap into the genius here in this forum. I've been reading through all the carb setup posts in search of what I'm needing. I don't think it is in here, but I do believe someone here knows that for which I'm searching.
(Quick disclaimer: I have been a member of the GMF for a while - please don't judge
I am building a rear-engine trike using a 97 Metro g10 with a 5 speed. I wanted to simplify this setup as much as possible (eliminate the ECU & TBI). Simple is my best friend!
I acquired an Aisan 2bbl carb already mounted to a 3 cyl intake manifold. I figured it would be a simple rebuild job and I'd be set. Then I found out it came off of a Suzuki Cultus (Japanese style). The tab on the top has 60B30.
I cannot find a rebuild kit anywhere, and I've tried several reputable online carb sites such as National Carburetors and Guaranteed Carburetors. I really need a kit since I found out today that the accelerator pump diaphragm is deteriorated. I'm making my own gaskets from bulk, but I may not be able to fabricate that diaphragm.
Is there anyone out there who knows where I might try to find a kit or some parts? I have lots of pictures I can supply, and can take more if necessary.
Thanks in advance for any help.
Fogger
