Correct.
This carburetor looked SO beautiful on the car.
And the car, even in the junkyard looked like it had been well kept by the owner.
The engine wasn't the cleanest, but that carb sure stood out.
I was SURE it was a winner, but was I wrong.
Now, let's take a quick look at that float level sight glass area again.
Here's a view from the top, inside.
You are looking as if you have the top of the carb off and you are standing on the left side of the car:
I'm not sure if the Photobucket picture has enough definition, but that O-ring has definitely jumped out of place and that would cause a SERIOUS gasoline leak.
If we look through some old threads in the MK1 section, we'll probably find out who's car it was.
"I just rebuilt my carburetor and now I smell gas..."
"I just installed a rebuilt carburetor and now it smells like gas, HELP!!!"
Etc.
Although you may have heard the term 'bowl vent solenoid' several times on Teamswift, you might never have seen one.
Here's the one which was on the carburetor; the screwdriver is pointing at it:
It looks fine, but there's one huge problem.
It is missing the plunger, spring and a couple of O-rings.
Here is what it should have:
The bowl vent solenoid (BVS) specs out with an ohm meter, but when I put the plunger in, and the unit on the carburetor, I wasn't able to see the plunger work properly when 12 volts DC was applied.
As they age, they can get hot on long journeys; perhaps this unit no longer works?
I'm wondering if the guy figured it would be best to remove the plunger because it didn't work?
What does the BVS do?
When you shut off the car, it seals up the gasoline portion of the carburetor so that the gasoline doesn't evaporate.
That means your carb won't dry up if you leave it sit for a long period of time.
Is that a good thing?
Certainly. It is a HUGE improvement over the old dual pumpers which are vented to the atmosphere and dry out if not driven daily.
The BVS can prevent the build up of varnish inside the carb.
You can see the heavily varnished check ball in the accelerator pump in the picture earlier in this thread?
Removing that plunger may have contributed to that.
Later we can take a better look at this.
If there are any newbies in the audience at this time, they might be paying attention and learning the virtues of the 'emissions cr*p'.
It's actually really good stuff.
Also, with the BVS functioning properly, the gasoline won't evaporate, so cold starting or starting after it has been sitting for a couple of weeks won't be so difficult.
"I just put a rebuilt carburetor on it and it runs like sh*t!"
How many times have we read that in a thread?
We generally take for granted (assume) that the carburetor was rebuilt properly.
What could possibly go wrong?
Ha!
That phrase was repeating itself in my head as I took a closer look at this super clean looking carburetor.
Now let's look at the body of the carburetor.
This is the 'meat' of the unit.
It's what has all the little passages and what usually gets the attention during cleaning.
I've circled an area in red:
For orientation purposes, you are looking at the Hitachi DFB 306 from the right side of the vehicle.
Closest to you is the bowl, where the gasoline is kept at a certain level by the float/valve assembly and the Mixture Control Solenoid (MCS) sits.
On the left, that hole is for the accelerator pump.
The next hole, circled in red, is the outlet for the accelerator pump and it dumps into the primary venturi.
Last, you have the venturi on the right, farthest from your view where the secondary opens upon hard acceleration.
Now that we are oriented on the picture, let's get an idea of what happens.
You step on the accelerator, the pump puts a small amount of gas into that hole circled in red, and the primary venturi sucks it into the engine.
Simple enough.
INSIDE that hole circled in red is supposed to be a check ball which is under slight pressure, keeping the accelerator pump area full of gasoline in case a small shot of gasoline is needed.
Here is what is supposed to be there:
From left to right:
-check ball
-brass weight
-spring
-brass weight
Upon disassembly, here's what I found:
-check ball
-brass weight
Our rebuild
Dumbo probably lost the two parts, didn't see the need to replace them with new ones or couldn't find some and figured no one would find out.
Would it run?
Certainly.
Would it pass an emissions test?
Nope.
That would be a favorite place for a tech instructor to rearrange during a final exam, no?
What would be the consequences of not including the other weight and spring to the rebuild?
I'm going to go out on a limb and guess that a negative pressure would be created in the chamber by the primary venturi.
Your engine would suck a certain amount of gas constantly from the accelerator pump area.
You'd have a heck of a time, because at idle, there wouldn't be enough vacuum to suck that gas out of the accelerator pump.
So you'd adjust everything at idle and she'd be fine.
As soon as you opened it up about a quarter throttle or more, the engine would start sucking gas not originally intended by the designers of the vehicle.
It would have a rich mixture and your HC would be high during a smog test.
There's one for you.
Leaving out two tiny, almost inconsequential parts would cause a car to fail smog.
Now I see why a lot of bumpkins hate smog testing.
They can't rebuild a carb correctly.
You, after reading this web site, certainly can.
Here on Teamswift, we try to help people with their cars.
Unfortunately, we cannot consider all possibilities with some vehicular problems.
A guy who posts something like, "I just put a rebuilt carb on my car and it is worse than before!" doesn't realize he's created the problem by introducing faulty parts to an already disabled vehicle.
We, trying to help, are only as good as the information you supply.
So don't pitch a bitch when we ask for pictures and videos of what you've got.
You bead blast a carb body and make it all nice and shiny, but you don't know what you are doing when you rebuild these puppies and you're creating bad blood between you and the end user.
These are not your 650 cfm dual pumper Holleys of the V8 era.
The electronics are there for a reason, as are the vacuum servos.
I've had people tell me they would rebuild these carburetors better than original and post how to threads with plenty of pictures.
They blow hard and even get some people to believe in them and send them their carbs for rebuild.
A year later? Carb still in a box somewhere, not rebuilt, waiting for us to post threads like this so they can rebuild it.
So that's why I'm a bit slow in posting this thread...I don't want to steal their thunder and I'm always willing to learn, especially if they know better than the factory.
A couple of guys have contributed enough information on how to rebuild these, so this thread is probably redundant, but at least you see a few problems which arise when people try and think outside the box with the Hitachi.
It is a simple unit, if you take it one step at a time and understand why each little part is important.
If you look at the whole unit, it might scare you.
Don't make that mistake.
In general, my threads try and take seemingly complicated things: installing wheel bearings, rebuilding transmissions, balancing engines, etc. and making them somewhat simple.
You won't find any "only I can do this" kind of crap in them.If I can figure out how to do it, you can too.
When I joined Teamswift I didn't know squat about Hitachi carburetors, etc.
The people here have a wealth of information which can be applied successfully to many car platforms.
Work safely, and consistently.
You'll save a lot of money by doing the work yourself.
But be prepared to ask questions rather than continue in your ignorance and screw things up totally.
That's how you'll learn.
People who rebuild carburetors for a living do it well and much better than me.
They are at a disadvantage in only one area, and even that it a limited one.
I have an MK1 to put the carb on and run it through emissions testing to make sure it is right.
That's why the carb rebuild people prefer to set up a carb on an actual car.
They have the emissions testing equipment to see what comes out the tailpipe and thus know their work is properly installed.
They do their best, but can only do so much if the carb is to be installed on a car out of State, for example.
It is very hard to provide a warranty on those items as you don't have a clue what the end user has done with your work.
These carbs are designed to work with a specific set of variables.
An ECM (not the newer PCM), no throttle position sensor (older type unit) and vacuum servos which are tied to the exhaust (oxygen sensor).
That's why I find it interesting that someone can build it better than factory, or so they claim.
I've been waiting to see how they'll do it.
There was a guy here (Geostalker) who needed help with these carbs a while back and I posted the needed help in his thread.
He runs over to GMF and calls me an idiot. Literally. In capital letters. Yep.
I called him out on it. (He asks for help, I provide the information and he calls ME the idiot?)
Never apologized. Instead said we were 'okay' now.
WTF?
Later, he had a problem with the adjustments after buying a 'rebuilt' carburetor.
His 'mechanic' wasn't able to solve the problem. (It was an idle up adjustment - very easy to solve.)
Son of a gun if I forgot to chime in and tell him what he was doing wrong.
Two years later and he's selling the car and it still has the same problem.
So who's the idiot?
He's been so busy posting on the forum he never learned what he was doing wrong and he's going to pawn his lousy work off on someone else?
Good luck with the sale.
Another odd ball story -
A few months ago, a guy asked me if I rebuilt carbs and how much.
I asked the guy if his car ran and he asked me 'what has that got to do with it'?
Obviously it has a lot to do with it.
If the guy can drive the car to my place, and we can set up the carb correctly, he will have something for his $400 carb install.
Apparently, he was thinking outside the box and had removed the oxygen sensor, etc.
Now how could you get a feedback carb to run right with all that removed?
Then he goes bitching how I can't build a carb? I don't think so.
The point is - you've got to have ALL the systems working together to get the best mileage and longest life out of your engines.
Enough of the rants.
With all the carburetor rebuild failures, there are many more successes.
Once you get them dialed in, if you drive them properly, they will give you excellent results.
All this carb information was taught to me, and
if I can learn, so can you.
BTW:
Has anyone done a thread on accelerator pump rebuilding?
I'm sure the Teamswift member who claimed he can "rebuild the carbs better than factory" would know.
Does anyone remember
that masked man?If you've read this far, and remember... a video/photo shoot on how to rebuild an accelerator pump for these Hitachi carburetors is a post worth saving on the site for future use.
Accelerator pump rebuilding is a dying art.
How many people you know can do it without destroying the hollow brass reed?
