It is currently Thu Nov 23, 2017 11:17 pm
PostPosted: Thu Aug 07, 2014 8:34 am
Hello all, im about to install an 86 carb into my 88 spint and was curious if anyone has any pointers as to what I might have some trouble with (car had a ford carb on it so I have no reference point) also does anyone know where I can find the base gasket for it? And or a gm part number. Thanks!
- Brian
1988 Sprint Plus
1998 Lincoln Mark VIII LSC
1991 Mercury Capri XR2
Former "fun" cars - 86 Sprint Plus, 69 Midget, 78 MGB, 86 Fiero, 90 Miata, 90 Reatta
PostPosted: Fri Aug 08, 2014 10:21 pm
Well the easiest approach would be to have a carb rebuild kit......But the quickest and cheapest is to get a roll of gasket paper and make a gasket yourself.
As for troubles or reference. If you are installing a Hitachi Feedback carburetor, then there are all sorts of things that will need to be addressed. Wiring harneses still intact, vacuum line routing, etc. The one you have, if not some history of a recent rebuild or actually off of a running engine, would definately consider going though it. If its been sitting up for some time, or if the MCS is not functioning, it can deal you fits trying to get it to run and to do so reliably. I am guessing that the one you are taking off was probably a very simple non feedback carb?
I would start by referencing the under hood decal for carb vacuum routing. Make sure that you still have ALL of the components that make a feedback carb hookup possible. So many of these cars have been butchered there is really no way to tell until you break it all down and see what is and is not still there. IF you dont already own a Factory service manual, that is the best start anyone could make. Not haynes or chiltons, but a GM manual, commonly found on ebay for peanuts. Hitachi feedback carbs are not impossible to learn but do take lots of studying and understanding to get em right.
Mike
Valley Grande, AL
1986 Sprint plus
Do you maintain a personal fleet like I do?
Why do we do it?
Because it's what we enjoy and because we CAN.
2011 camaro, 2005 Vibe, 2016 Outback, 06 Expedition, 87 Porsche 911, 87 Turbo sprint, 82 Brat, 73 gmc 4x4, 69 camaro, 99 Gl1500 Honda Goldwing, 12 Kawasaki klr650, 2012 Kubota L3200, and we wont even go into the small stuff.
PostPosted: Sat Aug 09, 2014 9:45 am
Thanks Mike,
I noticed the rebuild kit on Rockauto, but $20 seemed a bit extensive since I just need the 1 gasket (however the GM dealer quoted me $40 just for the 1 gasket!) The carb that was on it was from a 40's ford v8 and the engine stalls when I make a turn (took the carb apart and everything seemed fine, but even at the lowest setting the engine runs RICH) so i'm trying to get the car back to how it is supposed to be, the carb I have came from someone on this forum parting out their car and supposedly was recently serviced, it appears that all of the original equipment is still on the engine for hooking it up. The carb I bought has a small port, then a larger crevice that I wasn't sure how the gasket would be set up for, but I might just end up taking a guess and making one.
- Brian
1988 Sprint Plus
PostPosted: Fri Aug 15, 2014 4:42 pm
Brian,
if you choose the route of refreshing, take the time and contact TOMCO.
http://www.tomco-inc.com/
Tomco has been making carb kits for as long as I can remember. Some parts houses do still carry them but you can buy from them direct by calling the # on their web page. Most of the carb house in the past few years seem to be carrying a kit by Hygrade. Ive had lots of problems with those kits. Tomco's kits have been and still are the most thorough I have ever used, including all parts. Some of the cheaper kits often are missing some things most commonly the accel pump. Also their prices online are much cheaper than most kits bought at stores. Good luck and be sure to let us know how it goes.
Mike
Valley Grande, AL
1986 Sprint plus
Why do we do it?
PostPosted: Sat Aug 16, 2014 11:12 pm
My friend came over and traced out a new gasket from a gasket sheet.Still have to work out some things but it appears it worked out okay, guess I won't know for sure until I go out and start driving it in a few weeks lol
- Brian
1988 Sprint Plus
PostPosted: Fri Nov 25, 2016 1:41 am
เคล็ดลับบาคาร่า
PostPosted: Thu Dec 01, 2016 11:25 pm
I bought one of these rebuild carbs, have NOT had any problems. I just had to adjust the high speed idle, the cold idle was set correct. Check them out....
http://www.nationalcarburetors.com/look ... num=chv200
CHV200 $50.00 Core Charge Select Carburetor Pricing Options:
90 Days Warranty Price: $169.95
Order Now
Lifetime Warranty Price: $289.95
Instant Rebate: -$100.00 Off!
Sale Price: $189.95
Order Now
We Are The Most Trusted Name in Carburetors
You can trust us to do the job right. We have rebuilt millions of carburetors since 1954. We have the largest stock pile of carburetors in the nation. Be assured that we will have the carburetor you'll need. We carry Carburetors for: American cars and trucks, Import cars and trucks, Antique cars, classic cars, muscle cars, boats, and Industrial Engines. Plus we also carry a full line of Holley and Edelbrock Performance Carburetors.
The Rock Solid Choice
National Carburetors, Inc. is a second generation Family Business since 1954.
Fc Remanufactured Products known as (Foreign Carburetors) since 1974.
With over 30 Million dollars in Inventory and the most modern carburetor factory in the Nation,
we are "The King Of Carburetors"
Our Carburetors are Remanufactured to Highest Quality Standards
In order to provide you the highest quality remanufactured carburetors in the industry, each carburetor is individually built by our certified technicians using a master rebuilding kit. All other components are cleaned, tested or rebuilt to meet O.E.M Specifications. The base plates are rebushed to remove excess wear from around the throttle shaft to stop certain vacuum leaks. All bolts and linkage parts are zinc plated. As well as casings are tumbled to chrome like finish. Or by special request, Dichromate finish can be applied.
We recalibrated the carburetors for today's gas and remove the inherent problems like hesitations, flat-spots and hard hot starting. Every carburetor goes through a 3 step testing process, first a float bench and pump test, second a dyno flow bench test, and then a live engine test. All the adjustments are set for a bolt on and go carburetor.
Dale
1985 Chevy Sprint Mk1 G10 5 Speed Sky Blue
