I bought one of these rebuild carbs, have NOT had any problems. I just had to adjust the high speed idle, the cold idle was set correct. Check them out....
http://www.nationalcarburetors.com/look ... num=chv200CHV200 $50.00 Core Charge Select Carburetor Pricing Options:
90 Days Warranty Price: $169.95
Order Now
Lifetime Warranty Price: $289.95
Instant Rebate: -$100.00 Off!
Sale Price: $189.95
Order Now
We Are The Most Trusted Name in Carburetors
You can trust us to do the job right. We have rebuilt millions of carburetors since 1954. We have the largest stock pile of carburetors in the nation. Be assured that we will have the carburetor you'll need. We carry Carburetors for: American cars and trucks, Import cars and trucks, Antique cars, classic cars, muscle cars, boats, and Industrial Engines. Plus we also carry a full line of Holley and Edelbrock Performance Carburetors.
The Rock Solid Choice
National Carburetors, Inc. is a second generation Family Business since 1954.
Fc Remanufactured Products known as (Foreign Carburetors) since 1974.
With over 30 Million dollars in Inventory and the most modern carburetor factory in the Nation,
we are "The King Of Carburetors"
Our Carburetors are Remanufactured to Highest Quality Standards
In order to provide you the highest quality remanufactured carburetors in the industry, each carburetor is individually built by our certified technicians using a master rebuilding kit. All other components are cleaned, tested or rebuilt to meet O.E.M Specifications. The base plates are rebushed to remove excess wear from around the throttle shaft to stop certain vacuum leaks. All bolts and linkage parts are zinc plated. As well as casings are tumbled to chrome like finish. Or by special request, Dichromate finish can be applied.
We recalibrated the carburetors for today's gas and remove the inherent problems like hesitations, flat-spots and hard hot starting. Every carburetor goes through a 3 step testing process, first a float bench and pump test, second a dyno flow bench test, and then a live engine test. All the adjustments are set for a bolt on and go carburetor.
