nwbanks wrote:
I'll try to get some pics up soon. It's pretty ugly right now. The PO really abused it. The plugs were nasty, and there is a layer of crud about 1/4" thick over most of the engine compartment. The interior was filthy too.
Is there a different fuel pump associated with the single inlet model?
Yes, there is.
Don't worry about cleaning it up.
Most of us are used to the old ugly looking engine compartments.
My plug wires don't even match, so give a guy a break.
Just take some pictures as it is and over the years you can refer back to this thread to see how far you've progressed.
That altitude will be a little bit of a problem, but I'm sure you can figure it out.
DIY Broken Bolt Removal:
viewtopic.php?f=22&t=41042DIY Clutch Adjustment:
viewtopic.php?f=9&t=48281DIY Wheel Bearings:
viewtopic.php?f=2&t=29003DIY Shocks:
viewtopic.php?f=10&t=45483DIY Wheel Align:
viewtopic.php?f=2&t=42479Once you get the cars dialed-in (compression, leaks, bearings, alignment, brakes) swap in new rubber and glass, you've got something which should last for years!
