Spent all day today tuning and testing, I think I have things close to dialed in.
I started by getting the car to idle by adjusting the idle speed screw. She was a bit rough but idled well enough to get to operating temperature. I waited till the fan kicked on to do anything else, as that tells me that things are warm enough to considered operating temp.
Next I disconnected the vacuum advance from the distributor and adjusted the timing to max manifold vacuum, which should put you at the right amount of advance for the weber. After re-connecting the vacuum line to the distributor I then shut the engine off, and set the idle mixture screw to 2 turns out, and the idle speed screw 1 turn in from just touching the stop.
With these initial settings I started the car, and adjusted the idle speed screw to obtain roughly 800 rpm idle. At these settings the a/f gauge was reading extremely rich, somewhere in the 10 range, so I started turning the idle mixture screw in until the engine started to stumble, then backed it out until things smoothed out again. At this point the gauge showed about 14.5 to 15.5 (it bounces around a bit on my car due to the cam, so a solid number is hard to nail down). The idle had gone up a bit so I re set it to 800 with the idle speed screw. After getting to this point I gave it a bit of a rev to clear out any condensed fuel in the intake and checked the numbers again and making tiny adjustments dialed in to the aforementioned numbers.
Next I shut the car off and, counting the turns, turned the idle adjustment screw in until it just touched the stop. I found I was roughly 3/4 of a turn out from the stop, which meant that the idle jet is too big. So with that in mind, I got out the jet kit and replaced the primary idle jet with one 2 sizes smaller, from a 60 to 50. I decided to go 2 sizes due to how far in the screw was adjusted.
After this I re-set the mixture screw to 2 turns out and the idle speed to 1 turn in and started the engine up again. After adjusting the idle to 800 rpm, I performed the mixture adjustments as above and after shutting off the engine and counting the turns on the mixture screw found I was a little over 2 turns out, which is within acceptable limits, but may indicate the jet is a little small (more on that soon).
With the idle circuit fairly nailed down, I took the car out for a drive. I found that mild acceleration was showing mid 9's on the a/f gauge (way too rich) and full throttle was at about 10.5 (a little rich), and that attempting to hold about any speed below highway speeds the gauge was showing 17-19 (WAY too lean), and the engine was running quite rough. When I got home, I did a little homework which told me that the low speed circuit fuel flow is dictated by the ports in the primary idle jet, which would be the culprit for the lean condition at cruise, so decided to go 1 size bigger on the primary idle jet (55 in this case). I also kind of broke the rules a little (the rule being
only change 1 thing at a time), and, due to the obviously rich condition of the primary main circuit, went 1 size smaller on that jet (135 in this case).
After getting the idle mixture adjusted (again following the above procedure), I took the car out for another test drive. Immediately I found that the over-lean condition at cruise was eliminated. The gauge was showing 15-16, which is a little lean but the engine is pretty much simply coasting at this point so a little lean is OK here. Moderate acceleration was now showing about 10 on the gauge, and WOT was 11, so still a bit rich there.
When I got home after the 2nd test drive I changed the primary main jet 1 more size smaller (130), re-adjusted the idle mixture (which to my surprise was a little different after changing the main jet), and took it out for another spin. Moderate acceleration was a little over 11 on the gauge, still a little rich, and WOT was also still at 11, and cruise was a little smoother, but still showing 15 on the a/f gauge.
At this point I knew I was close to getting there, so when I got home I changed the air corrector out 3 sizes bigger (from 170 to 200). I went 3 steps because the air corrector has a smaller effect on the mixture and the book says 3 sizes on the air corrector is equivalent to 1 on the main jet. I figured that this would either get me right in the pocket, or maybe a little lean. When I took the car out for a test drive, I found that cruise was relatively unaffected, moderate acceleration showed 13.2 to 13.5 while in the primary, and opening the secondary took the ratio to 12.9 and up to 12.7 at WOT. All these numbers looked good to me, so right here I am going to leave it, and see how things go.
With the last set of adjustments, my butt-dyno could feel a definite increase in power, probably due to getting into the sweet-spot on the air-fuel ratio. I was rather surprised at how the secondary fell right into line once I got the primary ironed out, I was figuring that I would have to open up the carb a couple more times to get that taken care of.
My final jetting is as follows:
Primary Idle: 55
Primary Main: 130
Primary Air Corrector: 200
Secondary Idle: 50
Secondary Main: 140
Secondary Air Corrector: 160
One thing to keep in mind is that these jet sizes are going to be different for a car that is primarily stock, as I have modified my engine a bit by installing a fairly radical cam (226/395 from 3tech), shaving the head .027", and eliminating the EGR system. Someone getting a 32/36 working on a purely stock engine would likely end up with different jetting, a little 'smaller' on everything I would guess, and likely some adjustment to the secondary circuit would be needed.
I hope this write-up helps other people trying to get their Weber 32/36 DGV dialed in, and any criticism is welcome. Three things that made this process infinitely more manageable were my
Innovative MTX-L Air-Fuel ratio gauge, The book
'Weber Carburetors' by HP Books, and
this excellent guide at sv3power.com.
