It is currently Thu Nov 23, 2017 10:20 pm
PostPosted: Sun May 14, 2017 9:03 am
Hello,
I am looking into doing a 1.5 conversion to my swift GTi, after an accident at the tracks, I have to buy a new radiator. I used an ebay aluminium OEM replacement radiator with no problems at all in my 1.3 engine doing 112whp (stock compression). The temperature stood steady lap after lap with absolutely no problems.
My question to you is would this same radiator suffice for the 1.5 engine, if i were to build a high compression version.
Thanks,
Neil
PostPosted: Sun May 14, 2017 7:28 pm
Can't see a problem, the turbo guys are using the same radiator without issues and some of them are making twice the hp that a NA 1.5 will ever make.
PostPosted: Mon May 15, 2017 12:22 am
Thanks! Just was concerned with the lap after lap use.
