miniswift wrote:
Hi d & Mr. Pipe,
I have Peugeot 106 liners which is 75mm bore at the moment.
With these sleeves, I can go 80mm but I have to machine flat first to fit into G13B. So with 80mm bore you can have 1517cc. Toyota pistons, what size can you buy them? Do they have same size pin as well as width for con-rod?
I have managed to get a G16 Vitara oil pump and I will be fitting this to my engine. Since I don't have oil squirt hole in my con-rod, I will be fitting oil squirters with built in valve. G13B has so many casting boss which cater for all those mods I'm doing.
I hope all this mod will help my mod to get what I want from it.
Cheers
Atchi
The yota 4age pistons come in many guises the stock ones are
http://www.aclperformance.com.au/Toyota ... istons.htm4ag rods have a 20mm pin whereas suzuki rods 19mm.
Also the B16 pistons are possible with similar valve angles
http://www.aclperformance.com.au/Toyota ... istons.htmhttp://www.ebay.com/itm/Nippon-Racing-J ... 1012711994I would stay with 75mm for boost, proven and reliable.
Im doing the g16b 3rd stage motor to go after the current one which after
driving it on stock rods for more than a year now and getting revved often
to 7500rpm using g13bb flywheel, crank pulley and ported manifolds for
better flow and less exhaust reversion I got to say that Ive gained faith in
the cast cranked, spaghetti big block G series more than ever.
So looking at a bit more capacity again with bigger valves, better springs, 270 cam,
little more lift, bigger throttle body and stainless header 4 into 1 to 2 inch exhaust
and lighter billet alloy flywheel/ crank pulley.
Its nothing radical or record breaking but the extra capacity and tweaks should
be a punchier NA setup hoping for around around 105hp atw and loads of tq under
the curve which is actually priority.
Stage 4 will be boosted but most likely with stock bores with grouted bottom
end and forgot to mention got to find better rods & rod bolts!.
