Engine in the car and running great. A lot of work with fitting gearbox, making mounts, modifiy the driveshaft mount, ...
Setup:
- Cultus intake
- PM7 oversized pistons 76mm
- Oversized vitara block 76mm
- Crank and flywheel lightened both 1.5 kg and balanced
- P&P head
- Cultus cams
- Adjustable camgears
- Custom exhaust system (original upper part of exhaust mainfold)
TO BE DONE:
- fit SR20TB
- custom exhaust mainfold
- standalone ECU
- Baleno fuel ramp
A lot of power and torque, nice engine sound. Engine running smooth, some problems around 2.000 rpm probably with gasoline.
Blown headgasket after 15km, replaced and torqued 2kgs more.
