It is currently Fri Nov 24, 2017 7:15 pm
Post new topic Reply to topic  [ 3 posts ]
PostPosted: Sun Nov 12, 2017 9:22 pm
Hello everyone,
I want to build a g16 block with high comp pistons, I'm seeing people using the Honda p29 pistons but I would like to know what's the highest compression I can get away with, also going to use cams from 3tech. will be getting the pistons from him but he doesn't have all the info for the g16 engines. If anyone has any light to shed please assist :)
Thanks,
Neil
PostPosted: Mon Nov 13, 2017 12:33 am
I believe highest is 13.0:1
But do you really need highest compression? :lol:
sorry bout my bad english
PostPosted: Mon Nov 13, 2017 5:36 am
Building my car for circuit, but I want to go with 12:1 compression, just don't want to run into issues with the valves hitting the piston after installing cams.
Thanks!
