It is currently Thu Nov 23, 2017 7:58 pm
PostPosted: Wed Jun 22, 2016 1:56 pm
Hi all! My swift gti is constantly picked on by the hondas in my neighborhood. I have a few basic mods on it: cone filter, 60mm tb, TomsII chip, lighter underdrive double pulley, Cultus headers, De-catted 2 inch press bent exhaust pipes, cannon muffler. I want to run a 35 shot (wet) of nitrous. My goal is to run a 15.0 - 15.5 quarter mile time. Can i do this with my current setup? (i want to keep using the chip). What times should i be getting with a 35hp shot? Those with nitrous experience please share your knowledge. I have already searched past posts, just need some more info. Thanks in advance!
PostPosted: Thu Jun 23, 2016 11:53 am
My best time with 50hp dry in my 4 doors hatch g13b dohc its 14sec flat/ 100mph.
195/60r14 falken azenis rt615k
With stock tb
Stock intake
Stock fuel rail and injector
Big cam 8.50 lift
Header
2 inch exhaust line with no cat
PostPosted: Fri Jun 24, 2016 6:24 pm
Thanks for your input. Do you use the stock chip?
PostPosted: Mon Jun 27, 2016 5:55 am
No its not the stock ecu ..8500tr/min
PostPosted: Tue Aug 02, 2016 8:46 am
Any other nitrous users out there? Can I retard timing at the distributor, run the Tom's II chip and 35 HP wet shot and be safe and reliable?
PostPosted: Mon Aug 08, 2016 9:34 am
You dont need touch the timming with only 35hp .. only fire up at minimum 4000rpm.. its -2° for 50hp ... you can retard 1deg but ......
PostPosted: Mon Aug 29, 2016 5:10 pm
Update. I put back in the stock chip. Nitrous installation complete. 35hp on demand. Taking it to the drag strip soon.
