It turned out to be a bad configuration of the LM1815.
first of all, it was set to use the one-shot output with no R/C connected to the R/C config pin. I put the chip in mode 0, disabled one-shot mode, now we had something that kind of worked, but it was missing teeth randomly at some rpms. With the heal of a logicl anlyser, I was able to trace it to the LM1815 output not providing a good enough ground for the MS2 input's pull-up. Previous owner wired the output directly to MS2's mcu, bypassing the opto-isolator in place, but keeping the opto'S pull up circuit. I had a 1.5V-4V signal to MS2, and it would sometimes NOT see the low state with 1.5V. We tried external pull down, lowering input voltage to 1.3 but it was still not good enough (doesn't make sense to install pull-down resistor on a pull-up resistor anyways....). I only wired the LM output to the opto input, and BAM, I had a super clean 0-5V at MS2's mcu.
The absolute maximum input voltage for that i/o on that mcu is 1.7V for a low state. I think it was in some kind of grey zone and it was missing some transitions.
_________________ Suzuki Gold Master Tech '07 Suzuki SX4 JLX AWD 2.0 | Turbine Tech turbo kit @ 7psi'08 Suzuki SX4 Sport 2.0 , average baby carrier
