Sorry about that crank, good luck with that.
I painted my bumpers years ago, they were plastic, now they are Motip Matt Black. I simply sanded them with pretty coarse sandpaper, after that I gave them a wash with water and soap and a scotchbrite pad, rinsed them clean, let them dry and wiped them once with a cloth of thinner just to be sure. Then I applied two coats (I think, it's pretty hard to see where you've been already) of Motip Plastic primer and two coats of matt black. Still holds, almost 6 years later.
_________________ '95 Swift 1.0:
- 0,5mm oversized pistons - mildly ported head, 1,7mm taken off - ss exhaust valves - 222/365 3tech cam - +10 gear - K&N air filter - TBI bridge removed - 40mm throttle and intake manifold - srd underdrive pulley - AASCO 3kg flywheel with GTi clutch - GTi catback - deleted cat, now 2" ss pipe - 14x6J ET45 BSA Racing - Nankang AS-1 165/55-14 - 35mm lower Apex front and rear springs - GTi sway bar - Turbinetech underbody brace - Ultra Racing upper strut bar
0-100kph: unknown seconds
