The 95+ exhaust clears the front and rear bars perfectly.
Only 2 issues:
1) The Cat pipe has a down stream O2 bung, so you need to plug that up with an old O2 sensor or ???
2) The hangers on the muffler are pretty much all wrong. However, you can use them (one of the rubber rings slides all the way to the base of one of the muffler hanger arms. The only issue with this is the tail end of the muffler just touches the opening in the bumper of my 91 Metro. Yes, there was a tiny bit of melting, but it was so minimal, I did nothing. Yes, I know. I should have done something about it, but Close Enough.
Obviously, this is the ONLY WAY TO GO if you put bars on your Gen 2.
