It is currently Fri Nov 24, 2017 1:57 pm
PostPosted: Wed Jan 25, 2017 12:21 am
Hi guys long-time reader and metro owner. Finally decided to join and this seemed like a good reason. Picked this up a few months ago wanting to do an engine swap in my metro. Looks like the guy I got it from actually listed it on here several months ago.
Anyway I bought it rather impulsively (and payed more than I should have) since they never seen to come up around here and now I've realized I just don't have the time for this project.
Haven't really done much except clean it up a little and check compression, which was within range. Rear quarter panels are dinged up as is the hood a little bit. But it's all there, interior is pretty decent too. Will need the tank and fuel lines cleaned out after sitting quite a while. Clean CA title on non op. Anyone have an offer on it ? I'm hoping to get at least 600
PostPosted: Wed Jan 25, 2017 2:17 am
Where is the car located?
PostPosted: Wed Jan 25, 2017 2:44 am
About an hour north of Sacramento, sorry quite far if you're in SD
PostPosted: Fri Jan 27, 2017 11:00 am
damn... it took it from both ends.
good luck getting rid of it!
PostPosted: Fri Jan 27, 2017 11:32 am
The rear quarters are the only real damage, and the hood has a little as crunch, everything else is straight. That said if probably recommend as parts unless someone was feeling real ambitious
PostPosted: Sun Feb 05, 2017 4:22 pm
Still available.
