It is currently Thu Nov 23, 2017 4:31 pm
PostPosted: Fri Mar 12, 2004 3:10 am
King of Pompous
Here's some more FAQ links...
SOHC to DOHC Swap
Lessons Learned From MSD Install
Using Larger (Nissan) Throttle Bodies
Guide to fit a SR20 Throttle body
Injectors/Fuel Rails, flow and control
How to install oil cooler
Apexi wiring FAQ
The right tool for the job...
As usual I'll be looking for more to add to this list.
PostPosted: Thu Oct 05, 2006 2:55 am
Moderator & FAQ King
Swift GTi common maintenance/troubleshooting PDF/JPEG files:
http://www.teamswift.net/viewtopic.php?t=5040
Distributor oil leak/ O ring:
http://www.teamswift.net/viewtopic.php?t=27516
Speedo cable gear oil leak:
http://www.teamswift.net/viewtopic.php?t=11929
http://www.teamswift.net/viewtopic.php?t=13367
Timing Belt:
http://www.teamswift.net/viewtopic.php?t=15962
http://www.teamswift.net/viewtopic.php?t=11669
http://www.teamswift.net/viewtopic.php?t=10151
http://www.teamswift.net/viewtopic.php?t=9503
http://www.teamswift.net/viewtopic.php?t=6907
http://www.teamswift.net/viewtopic.php?t=6469
http://www.teamswift.net/viewtopic.php?t=1606
dohc cam gear question .. cam advance w/ stock pulleys ?
Suzuki Timing Belt Guide (PDF file) credit to Knuckles for providing this file
Lifters:
Stripping and cleaning lifters
Diagnosing good and bad lifters
Throttle body:
Nissan 55mm TB custom idle switch + brand new TPS find
using larger (nissan) throttle bodies
MAF: (mechanical)
Cleaning the MAF (mass airflow sensor)
60 mm TB and 60 mm MAF
bored afm
Electrical:
Full vehicle wiring diagrams:
1989 M/T (TIFF)
1990 M/T Canadian market (PDF)
1991 A/T Canadian market (PDF)
General:
General Electrical Index (wiring, starter, lighting)
Factory Service Manual Electrical Section (harness routing, grounding points)
Fuse block diagram
Fuse block wire colors
Ignition switch continuity table
Combo switch and light dimmer
Wiper wiring schematic
Wiper switch continuity table
Chassis ground points
Battery drain/doorswitch
ECU/Sensor:
ECU diagnostic codes (PDF file)
ECU connection diagram (Swift GTi)
Code 21, Code 22: Throttle Position Sensor (TPS) diagnostic
TPS calibration diagram
TPS and idle speed adjustment
surging - TPS adjust--FAQ
Code 24: Vehicle Speed Sensor (VSS)
Code 33, Code 34: Mass Air Flow (MAF) sensor diagnostic
How to adjust base timing & the IAC
foreign market air/fuel ratio trim knob and ECU differences to support it
Differences between MK2 & MK3 ECUs
ECU chip installation:
http://www.teamswift.net/viewtopic.php?f=29&t=4708
http://www.teamswift.net/viewtopic.php?f=4&t=16545
FI fuse / ECU blowing:
http://www.teamswift.net/viewtopic.php?t=27489
http://www.teamswift.net/viewtopic.php?t=14867
Transmission
MK2/MK3 Suzuki Swift FSM - Section 7A Manual Transmission
alternate tranny (gear ratios)
Vehicle Dimensions:
mk1 & mk2/3 vehicle dimensions
Chassis alignment measurements diagrams
Suspension:
Re-oiling shocks:
http://www.teamswift.net/viewtopic.php?t=1352
http://www.teamswift.net/viewtopic.php?t=1164
http://www.teamswift.net/viewtopic.php?t=1057
Wheel Studs:
http://www.teamswift.net/viewtopic.php?t=1126
Torque Specs:
steering / suspension
Oil Filter / Oil Cooler:
Remote Oil Filter and Cooler
oil cooler tips
Misc
Identifying a motor by it's intake manifold
The difference an 'i' makes
File comment: ECU codes for MK2/MK3 Swift GTis
codes.pdf [113.23 KIB]
Downloaded 692 times
( miracle pour hole)
maybe a picture Thanks
