It is currently Thu Nov 23, 2017 4:58 pm
PostPosted: Wed May 03, 2017 12:22 pm
Is there any reason why a g13b oil pump would not fit a g13bb 16v sohc? I'm not worried about the crank sensor, just if it will fit the crank without binding or scraping anything
PostPosted: Wed May 03, 2017 2:16 pm
bolt on, did a dohc engine with a 2000 swift 1.3 crankshaft and block once
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
SRP forged civic piston
cusco 1way LSD
