Hi, when i swapped the 55mm sr20tb (was already running a cultus intake) in my samurai gti i'm having an idle issue.I have the tps adjusted as usual with a filler 0,65mm from tb adjusting screw(which i did not touched).Then When cold idles to 2000rpm which is ok.At hot operation idles on 900rpm which is good.But the problem is when i operate the hydraulic steering wheel in a static potition,rpm drops alot to 400-500rpm which often stalls the engine.Then i have to crank it again. If i put back the stock tb and readjust the tps,i dont have this issue.It drops to 700-800rpm.So there is something to do with the tb.Beside this is running great and gives a great response and sound.. Should i raise a bit the idle from the adjusting screw and readjust the tps or look something else.
