It is currently Thu Nov 23, 2017 4:48 pm
Post new topic Reply to topic  [ 62 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu Aug 30, 2012 6:18 pm
That engine bay pic is just sex!!! :yeahyeah
I see now you did something to the car flares. Also to the rear wing. Care to share a few close up pics? :D
I have Suzuki's fiberglass fender flares installed on my '89 project. I also have a modified OEM wing on it which looks very similar.
Awesome car you have there.
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Tue Jan 22, 2013 12:11 am
This is a really inspiring project, you have going on here :wink:
I noticed you mentioned a 95% volumetric efficiency on your first post.... what equation did you use to come up with that number?
I ask because I've been doing some calculations on intake and exhaust flow and according to my equations, your engine should be way beyond 100% VE in order to generate those numbers.
By example the B16 generating 160 hp = 97% VE and a stock G13B 100 hp = 86% VE
image_id: 22616
1993 Swift Gti
PostPosted: Thu Jan 24, 2013 9:03 pm
dang, this car gets all 5 stars, really impressive. inspiration for my current project
u ever consider bringing this machine over here to jamaica and give them evo this and sti that guys a good run? i would love to see this in person.
doing a rebuild now (on a budget) looking at the p29 floating pin pistons i see on ebay. high compression & boost later.
wish i had a car like runbag, wonder if he would help me build 1?
PostPosted: Thu May 19, 2016 11:09 pm
Hi Guys,
Does anyone know where I can locate a dry sump oil pan for the G13B motor? I don't have the means to make one.
dry sump motor.jpg [102.8 KIB]
Not downloaded yet
PostPosted: Fri May 20, 2016 10:24 am
There was a fella a few years back that posted pics of a g13 in a super seven, rwd and dry sumped, Im sure it was custom, isnt there any fabrication shops near you?
Have a look, you know you want to!
Swift. http://m.flickr.com/#/photos/11473969@N02/
Evo. http://m.flickr.com/#/photos/100754123@N04/
PostPosted: Sat May 21, 2016 3:14 pm
Here is the post on the guy with a dry sump.http://www.teamswift.net/viewtopic.php?f=4&t=60867&p=446056&hilit=lotus+7#p446056
PostPosted: Sat May 21, 2016 6:08 pm
Hey, thank for the link. I sent him a PM some weeks ago but reply as yet.
Cheers,
MF
PostPosted: Sun May 22, 2016 12:59 pm
Found this link http://www.drysump.com/
PostPosted: Mon May 30, 2016 8:45 am
Subscribed for the dry sump...
I'm in the process of dry sumping mine as well... My biggest hurdle is mounting a drive gear to my pulley
PostPosted: Mon Apr 03, 2017 10:52 am
Hi Guys,
I had to abandon the dry sump project because of the group/class rules :( I am looking for recommendation on a good high volume / high pressure oil pump and a high capacity oil pan w/ baffling.
Thanks in advance.
MF
PS. Please PM me your comments if you don't feel comfortable posting in this thread.
PostPosted: Tue Apr 04, 2017 9:11 pm
MF89 wrote:
Hi Guys,
Thanks in advance.
MF
I will be using the g16 pump this year and I am also looking for a high capacity/baffled oil pan..... I think I will have to custom modify a factory one.... I do believe Moroso will custom make pans but they need a drawing to build by.... so unlessyou are good with CAD or at making blueprint drawing then we are both in the same boat.
1999 suzuki swift ice race car... Dohc engine conversion, 3tech 222/365 cams, bored tb, aasco lightweight flywheel, 4.56 final drive, Welded Diff, cultus intake, srd 4to1 header, spool forged rods, Megasquirt PNP, H&R sport springs and Koni yellow shocks.
PostPosted: Mon Jun 26, 2017 9:48 pm
Thanks
Users browsing this forum: Google [Bot] and 5 guests
