Update Nov 2006This thread is a relic from the early days when Teamswift exclusively catered to Swift GTis. Issues with file hosting have now been resolved. I will be preserving the information in this thread due to massive linking this thread has received over the years. Information for non-GTi vehicles can be found in their own specific forum sections. Any future information will also be added to those sections as well.
Update Apr 22 2007This thread has now been moved to the GTi section. To keep this from getting clutter, I've also separted all extra comments that were once in here into a separate support thread. If you're having problems with the files here or have other comments or concerns please direct it to the following thread:
http://www.teamswift.net/viewtopic.php?t=31759Update Apr 29 2007I just ran across some wiring diagrams that were originally on the GTicouple website, but were never hosted here because they were too large to uploaded as attachments. There here now that we have proper FTP server for larger files.
Update Sept 18 2013A number of images in this thread had broken links, and in some cases the files were missing completely since the last server migration. Links have all been fixed, and replacement images have been uploaded to replace the lost files. If any links are dead in the future, please PM me so I can fix it.
Swift GTi PDF files originally from the long-dead GTicouple website:
Full vehicle wiring diagram, 1989 M/T (TIFF):http://www.teamswift.net/Lihtan/gti/89-GTI-Wiring-Diagram-G4.tif Full vehicle wiring diagram, 1990 M/T Canadian market (PDF):http://www.teamswift.net/Lihtan/gti/90-GT-MT-schematic.pdf Full vehicle wiring diagram, 1991 A/T Canadian market (PDF):http://www.teamswift.net/Lihtan/gti/91GTAutomaticCDN.pdf Canadian Daytime Running Light (DRL) system:http://www.teamswift.net/Lihtan/gti/DRL.pdfECU circuit inspection (includes pinout, and correct voltage levels):http://www.teamswift.net/Lihtan/gti/ECM-Coupler.pdfIgnition circuit diagram:http://www.teamswift.net/Lihtan/gti/Ignition.pdfFusebox circuit diagram (also includes fuse position legend):http://www.teamswift.net/Lihtan/gti/junction-fuse-block.pdfIdle Speed Control (ISC) solenoid check:http://www.teamswift.net/Lihtan/gti/Solenoid-Valve.pdfLocation of timing marks:http://www.teamswift.net/Lihtan/gti/timing01.pdfAllowable range of camshaft movement with timing belt removed:http://www.teamswift.net/Lihtan/gti/timing02.pdfThrottle Position Sensor (TPS) check and adjustment:http://www.teamswift.net/Lihtan/gti/tpsadjustment.pdf*
Warning buzzer operation and circuit diagram:http://www.teamswift.net/Lihtan/gti/warning-buzzer.pdf**
*In the original factory service manual, the resistance between pins C - B is stated as being 0 - 500 Ω (ohms). This was later revised in TSB # TS4-1606082 to 0 - 2000 Ω (ohms)
** This data has textual errors corrected in a later Suzuki TSB (not currently online)
EDIT Mar 07: fixed links, oops.
( miracle pour hole)
maybe a picture Thanks
