[This is copied from a post I made in May, 2013. I promise the prices have gone up, so don't think it would be as reasonable. Just a hint, if you don't care for the 2" from the resonator on back you might go for 1 7/8" or 1 3/4". But I'm really happy with it, as the local exhaust shop did a great job on fabrication from the resonator back. A plus, if done right you can have it done where you can put on anti-sway bars. Those help. Cut springs from a 97+ on also are a good idea. IMHO. ]
"What worked for me: ebay manifold to converter Magnaflow 93135 2" stainless $137.19 delivered ebay AERO AR20 stainless resonator 2" $38 delivered Auto Zone Thrush Turbo 2"
Butt-meter has better running, better fuel mileage. Top gear (4.11) seems to have a tourque increase. Not a bit loud or obnoxious. With the top up, can't really hear the exhaust. Top down, does not interfere with the radio."
_________________ '91 Metro 3 cyl. 'vert. 5 speed beater, built as a fun daily driver. '92 Metro 3 cyl. 'vert. Auto, all factory clean. '92 Metro 3 cyl. 'vert. 5 speed beater back up. '91 'vert with factory 160 hp 13B two rotor, Very clean RX-7.
