It is currently Thu Nov 23, 2017 2:05 pm
PostPosted: Tue Jun 02, 2015 8:27 am
This may be a old question, bear with me. I have a 91 vert. The bracket that comes attached to the bottom of the side piece has come off. Can it be reattached, or do I just find a new side piece, ebay or wherever?
PostPosted: Sun Aug 02, 2015 7:04 pm
which side do you need? (drivers or passenger)
91 Metro Convertible, 5sp, Fed Emissions, no A/C
PostPosted: Sun Aug 02, 2015 8:21 pm
Did the hinge come off the plate that is molded in the cover (held on by 2 screws) or I'm assuming the " dreaded "plate that is molded into the cover has been pulled out of the cover? As to previous post/question what color?
If your using more than 3 cylinders your just wasting gas.
I spit on hybrids at stop lights.
PostPosted: Sat Dec 12, 2015 6:33 am
Hi, I know it's an old post, but I need the part badly, it's a driver side hinge that connects from driver side pillar to the driver side tonneau.
Appreciated if someone could sale that part to me.
PostPosted: Sat Dec 12, 2015 7:20 am
What color? There is black, light gray, and dark gray?
PostPosted: Tue Aug 02, 2016 1:42 am
I am still fighting with the dreaded plate that has come undone from the side tonneau cover. J B weld held for a while but finally gave in. I need a black drivers side piece. I am going to try screwing it back on through the plastic until I can get a replacement. Question, when the top is up I can't get the tonneau cover to fit back in place.It seems like something is missing to hold up the center back piece. Does anyone have pics to show what I maybe missing ? I can't find anything online or in a manual to look at and there aren't any to see in person. I will post pics of what I have. THANKS
PostPosted: Tue Aug 02, 2016 7:42 am
Here is a diagram of the top boots. The back inside of the outer boots are held up by a fitting (#13) in the center boot. It fits in the oval hole(#14). It also rests on a rubber fitting on the car(not shown). The second pic is a type of pop rivet that the bottom expands. Might try this before drilling a hole through the boot.
PostPosted: Wed Aug 03, 2016 2:22 pm
Thanks I'll give it a try. I am missing the rubber foot or feet ( not shown ) of course. It's hard to tell what's missing when they don't show it.
PostPosted: Mon Sep 12, 2016 3:20 am
I had the nuts fall out of one of my side covers and I just fiber-glassed them back in. Carefully drilled out for the screws. It's still holding 7 years later as far as I know (sold the car but still see the new owner).
There are supports to hold the rear cover up (part # 5 I think). They attach to the body. They come in 2 different thicknesses. You may need the thicker ones. I couldn't tell you which years used which thickness but it's a problem I solved because I had a set of both types.
Hope that helps you.
