stevieh6 wrote:
Hi, im looking at buying the econo cam with +10 advance cam sprocket.
At present i get around 55mpg doing on average 55mph at 2500rpm.
Doing the same speed and revs will i see a difference in mpg?
thanks
Stevieh6 I suspect that I am the friend that 3Tech is talking about. I installed one of his cams in my 94 3/5 hatch in Oct last year. Since then I have been experimenting, testing, tweaking and repairing wheel bearings etc.
I have finalized my cam timing at + 6 having tried many settings up to and including one full tooth (18 degrees) advanced. I have a 66 mile commute and I drive at 100 km/h, 62mph. 175-70-13 tires not super over pressure. I am running a 4.10 trans but am going to change to a 3.79 as I suspect that the added torque of the econo cam will pull the extra gear.
Ign timing @ 12 degrees now, just shy of detonation.
My last tweak was to replace a bad MAP sensor and since then I have run through 4 tanks of fuel. Each tank has been better than the last and all four tanks have been above 65mpg IMP. The last tank I wanted to see how far the Metro would go on a full tank so I put exactly seven litres of fuel in a can and ran the car completely dry. Here are the results including the seven litres and then filling the tank to overflowing 1 km later at the gas station. My current tank is at about 450 km and I can tell you right now that it is going to hit the 70 mpg barrier barring any strange things.
Distance travelled
1006.8 km
625.63 miles
Fuel Amount
42.000 litres
11.1 US gallons
9.24 Imperial gallons
Fuel Economy
4.17 litres per 100 km
56.38 miles per US gallon
67.72 miles per Imperial gallon
If anyone ever says that the econo cam doesn't save them gas then they don't have a good running car to begin with or are driving with a very heavy boot on the right foot.
If you drive a lot on the highway there are two additions that are gold as far as helping get the best from the econo cam. Aero mods including grill block and airdam and a vacuum gauge. Here is a pic of my airdam worth about 4+ mpg and my vac gauge worth I don't know how much because I am still learning how to use it to best advantage but it is really, really helping. The vac pic was my temporary location. It is now mounted on the dash.
