It is currently Thu Nov 23, 2017 9:45 pm
PostPosted: Mon Jan 09, 2012 11:11 pm
2000 1.0L, 5sp, 110k miles. I installed an XFi cam (measured and confirmed) with the 2000 cam sprocket, and a tranny from a 1.3L (3.92~3.96?, its been a while). Stock exhaust, intake opened up a bit with TB bridge removed. Also running 175/65/14's. I usually get low 40's mpg with this set-up.
I know the wider tires lose mpg but I was hoping for near 50mpg. Do I need an XFi ECU? I never thought so, but doesn't hurt to ask.
PostPosted: Tue Jan 10, 2012 12:34 am
you can buy an economy grind camshaft that gives more torque and will maybe give you 50mpg levels. i would suspect low mpgs like that could be vacuum or compression loss. how is your hg at idle and what's your engine compression levels ?
PostPosted: Tue Jan 10, 2012 6:59 pm
I have the same set up. I am getting aroun 45 mpg summer time. Whats ur speed on the highway? Also do u drive more highway or city
My bad I meant closer to 55 mpg highway. Now im getn 46ish. And the xfi ecu isnt needed
PostPosted: Wed Jan 11, 2012 1:54 am
An Xfi computer will not work in your OBD II car. They were all OBD I. My car is only getting 42 mpg right now but will get 50-51 come summertime. :)
91 Metro,93 Swift 1.3L 8-valve, 3.5 tranny, late front brakes, swift rear discs, late sway bars, Esteem seats, 205/50r 15s, build:http://geometroforum.com/topic/4850034/1/
Swift bumpers and taillights :D
I sold this car to a friend at work. I now have a Saturn L which is an Opel Vectra B.
PostPosted: Sat Jan 14, 2012 11:33 pm
I wasn't thinking, I knew the old ecu wasn't obd-II. My driving is part 75~80mph freeway, part around town. I'm good now. Did a lot of work to get good mpg, but it is what it is, so now I'm just going to drive and not worry about it. Thanks.
PostPosted: Mon Jan 16, 2012 12:35 pm
It's most likely the larger tires. Make sure you get the speedometer set correctly for the tires you run. Narrow, 12" tires will give you the best mileage, go to narrow 13" if you want. Yes, they look like sh!t, but you will get better mileage.
PostPosted: Thu Apr 12, 2012 8:40 pm
So i was getting 45 mpg and sad. i really changed the way i drove. and that helped a ton with my 98 metro. duct tape my front bumper so more aero. removed ps mirror. got a ultra gauge obdii mpg computer and xfi cam. got 56mpg at last fill up. thats best ever mpg. start driving like a granny. and try not to go over 55. and put the 13inch wheels back on.
good luck.
