It is currently Thu Nov 23, 2017 9:16 pm
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2
PostPosted: Sun Jul 05, 2009 1:59 pm
Swift 1.0 L, 2000, 120 000 km
City traffic 6 l/km
Highway 4.6-4.8 l/km, on the car filled with low-quality Russian petrol mixed with all sorts of crap :shock:
G10a engine is the best one there is.
PostPosted: Sun Jul 05, 2009 9:56 pm
bmg_customz wrote:
Just got my new best at 57.2 mpg with mostly highway driving. My previous was 48.7.
1993 lsi with:
1994 xfi engine and 5-speed
kept lsi computer
open exhaust from axle back
intake tube removed
42 psi in the ol' 12 inchers
new and improved lightweight right foot
Ok, I just got my new best---67.7 mpg!!!!!!
All hwy driving (45-65 mph) and same mods as above plus lower grille block (minus about 5 inches in front of radiator)
1993 GEO METRO 1.0 lsi (xfi swap)
1995 Eddie Bauer Exploder
1983 CHEVY C-10--the gas guzzler
1997 VW GTI VR6 Turbo--dead as a door nail
1994 GEO METRO 1.0 xfi (retired and parted out)
1989 Suzuki Swift GTi (sold)
PostPosted: Mon Jul 13, 2009 6:46 pm
banned and still posting
Hmm... interestingly my DD has been down for a week and I had been DD the Swift. 2 tanks I got 35.5 and 36.1mpg back to back. Not bad for the way I drive.
PostPosted: Mon Jul 13, 2009 8:27 pm
Turbo'd 94 GT flogged daily, averages 34-36 mpg with mobil 1 synthetic in the engine and GM syncromesh in the trans. On long trips has done over 40 mpg.
I track my mileage every tank, and since the switch to synthetic it jumped a consistent 2-3 mpg. That and I don't change it as often (7-10k miles) I'm never going back to standard oil......
Anyone who's been around children will tell you that they are in fact quite stupid. Many of them cannot even read.
PostPosted: Sat Jul 25, 2009 4:00 am
97 Geo Metro Lsi, 1.3L, Automatic, A/C, 160,000+ on odometer, 155/80-13 tires at 40PSI, Moble-1 10/30 full synthetic, Quaker State synthetic auto trans oil.
Texas Hot Summer weather 100+degrees, A/C on, 65mph, tire pressure 40psi, all stock.
48mpg highway, 32mpg city.
And Obama wants me to trade it in for a gas guzzler? I think NOT!
Fainya
PostPosted: Wed Jul 29, 2009 7:48 am
1986
forsa swift GLS 3door
1000cc 3cylinder NA carbed engine (bone stock)
12x6j TRD tosco wheels (approx. 4kg/wheel )
185/70/R12 tyres
30psi on all four tyres
stop n go city driving with AirCon on
avg. temp. 32 degrees celcius
leaded regular gasoline with RON87
avg. fuel consumption is 15Km/Ltr
top speed ever achieved is 130+ Km/H
so far it is the best fuel saver car i ever had.. :D
PostPosted: Fri Aug 07, 2009 2:58 pm
98 swift 1.3 16V 5 speed
42.3 mpg 95% hwy driving at 65-75mph.
185/70/13 tires at 40 psi. otherwise all stock. crap for oil. who knows whats in the trans. no air filter.
98 swift 1.6 16v swap
03 cobra bolt ons
too many others to list
PostPosted: Sat Aug 22, 2009 4:02 pm
1987 Chevrolet Sprint turbo
189,xxx miles
Car is stock with pre-cat removed and tires/wheels upgraded to 185/60R14. Per http://www.miata.net/garage/tirecalc.html, this should be a 7.8% difference in speedometer/odometer readings, making my recorded MPG 7.8% lower than reality. However, my wife paced me with her car and said my speedo is dead on so I'm not sure what's what.
39.2 MPG from Seattle to Vernonia - mostly highway with a few hills at 60--65 MPH.
Last 4 tanks commuting 60-65MPH (~3 miles city, the remaining 32 miles each way are split evenly between 4 lane highway and 2 lane mountain highway:
38.7MPG
35.4MPG
34.7MPG
36.5MPG
1987 Sprint turbo
1989 Dodge Caravan SE turbo 5 speed
1991 Honda ST1100
2000 Nissan Altima
PostPosted: Fri Aug 28, 2009 1:17 pm
1991 Geo metro 1.0 Auto, was getting consistent 42 MPG mostly rural roads (45-65mph)
-Upgraded to 13" tires and run them at higher pressure
-Drilled cam gear +10
-Advanced timing
-low restriction exhaust and air cleaner
Just did a bunch of aeromods to it (some of which might actually be hurting it).
Haven't driven it enough to check the mileage yet but I have an MPGuino on the way.
1991 Geo Metro 2dr HB 1.0 Auto
PostPosted: Sun Sep 06, 2009 10:42 am
1988 Chevy Sprint Metro. (Sprint ER by any other name) Original cam and transmission. (3.79:1 final drive)
Driven carefully at 65mph, without too many hills, and with no substantial wind: 52 mpg (The OKC - Dallas run on I-35 is my usual test.)
Same conditions at 55 mph: 60.4 (But I've only tried that once.)
In general, I find that each extra mph costs me about 0.7 - 0.8 mpg, in that speed range. At 75, a don't expect more than about 44 or 45 mpg. But I'm less certain about that because I just don't drive it that fast very often. I don't really like pushing it past 3000 rpm, and that falls at 68mph for this car. Of course, my 92 Geo Metro automatic hits 3000 at 45mph. But I don't really like that car, so I don't care. :wink: I've run that one at 75 mph with a shop tach connected, wires run around the driver's door frame. 5000 rpm, if you can believe it. Those 3 spd, non-overdrive, automatics without even a locking torque converter were like something straight out of the '70s!
Edit: I should mention that the tires are P155/80-R12 and I generally keep them at at 35psi. (Sometimes 32psi) Everything is pretty much stock. Except that we went with the "regular" 3 ring pistons, rather than the 2-ring, during the last rebuild. And any possible difference has not been detectable.
I would suggest that the more pertinent details one can give in this thread, the more helpful the numbers will be to other members. :)
PostPosted: Wed Apr 21, 2010 1:54 pm
Current Mods:
'95 Metro LSi
TB bridge removed
Cone air filter
8 degrees BTDC
89 octane
Stripped interior (only driver's seat, spare tire, and dash)
1.5" exhaust (no cat) 2" after glasspack to a universal N1 muffler
52-52MPH speeds
Filled up last tank and got 60.41 MPG
AKA/FKA: 95_g105spd
PostPosted: Sat Aug 28, 2010 3:22 am
'95 Swift Gti
Big cams, under drive pulley kit, removed air-con compressor and dryer, stripped interior, light weight 17's 205/45 @ 40psi, 4-2-1 headers, hi flow cat 1.75inch pipe. 98octane
14km/L so 53MPG
Still sees redline every day.
PostPosted: Thu Oct 21, 2010 2:16 pm
94 xfi - no mods
Winter I get around 48mpg summer I get 54mpg (with 3 people and trailer attached) ie about 800-1100 pounds in the car plus the trailer.
Extreme Highway driving the best I have gotten is just shy of 59mpg
this is all E10
on E0 with winter gas I get 55mpg Have not tried it really on summer gas yet as its hard to get and I am pretty busy in the summer time.
PostPosted: Wed Mar 23, 2011 6:38 am
-lynel- wrote:
'95 Swift Gti
14km/L so 53MPG
haha bad to quote myself but my figures were wrong and iw ant to clear it up. i now get 14.5-15km/l which i believe is 55km/usGal which is 32.3MPG. I forgot to reduce km to miles.
While fe isnt my ultimate goal, i like to keep track of my FE as it usually is a good representation of how my engine is going and how dire a service is. Always use Mobil1 suspersyn products.
PostPosted: Tue May 24, 2011 9:06 pm
1991 Swift with 1992 GTi DOHC engine swap.
Just made a personal best of 40.3MPG. It also ran the 1/4 mile 16.891 @ 82.04mph May 13th.
- Elevation: 3450ft. (thought this was worth mentioning)
- SuzukiRD Stage 2 CAI with cone filter
- SuzukiRD aluminum underdrive pulley
- cat removed
- 4.10 final gear
- 4-2-1 header
- NGK Iridium plugs
- fresh 165/65/13's @ 32psi
- no back seat
Nick Manning
2006 Scion xB (fun-mobile)
1990/92 Suzuki Swift GTi TURBO (The GTiT)
PostPosted: Tue Jan 06, 2015 11:09 pm
Mine is 17km/L or 39.99 MPG with A/C On
Vehicle Details are:
Suzuki Cultus MKII - HatchBack 4 Door/5 Door
Manufacturing Year: 2010 ( As its still in manufacturing in my country)
Engine: 993cc 4 Cyl
Tires: 175/70/13R
Steel RIMs
Stock (No Mods)
2013-12-19 19.30.11.jpg [441.89 KIB]
Not downloaded yet
PostPosted: Wed Jan 07, 2015 5:13 am
Now in winter my average MPG is about is 28.23. or 12km per L.
and that's good :)
but I let my car sit a while before driving and kinda smells rich, :clap:
and here a L of 95reg is 1,4$
1995 Suzuki Swift 1.3 16v GTimk3 74kw
2005 Suzuki Ignis 1.5 16v GS VVT 73kw 4x4
2002 Lada Niva 1.7i+lpg 4x4
