It is currently Thu Nov 23, 2017 4:26 pm
PostPosted: Fri Sep 09, 2016 4:58 am
Going through eBay I came across a felt gasket that is said to go under the distributer. I can't find any other info on it and want to make sure I'm not missing something.
"She wasn't much of a wrestler,,, but u should of seen her BOX"
PostPosted: Fri Sep 09, 2016 3:01 pm
Rubber formed gasket for under cap
O-Ring from shaft to head
PostPosted: Fri Sep 09, 2016 3:09 pm
Thank you. So just the o ring on the shaft. I was thinking a washer under the distributer would sit funny when bolted down but just wanted to make sure.
PostPosted: Sat Sep 10, 2016 1:20 pm
Distributor Housing Seal (O-ring) part number 96056644
The NA is part number 96052013
If you get an OEM illustration guide, it is in section 2.
PostPosted: Sat Sep 10, 2016 5:49 pm
Cool. Thank you.
PostPosted: Tue Nov 15, 2016 10:44 pm
Thank you. :)
จีคลับ 1688
PostPosted: Thu Nov 17, 2016 12:18 am
This may be what you're after, likely the Ebay listing is not this actual seal for the MK1 T3 Turbo Distributor.
The round seal fits on top of the dust cap that covers the distributor internals, fits inbetween the dust cap
and the distributor cap. Over time they crack and fall out during maintenance and are not missed because
they are unobtrusive and unnoticed. For all you know yours is still in position and intact.
can you post the Ebay link? I'm curious
So what is the deal with the Mitsubishi parts all over our Suzukis?
Too bad we can't ask Michio, but he passed 5 years before our rides were created,
but it all started here:
https://en.wikipedia.org/wiki/Suzuki_Suzulight
Still love these cars, basic and relatively easy to understand,
still wish I had OBD1 reader to access ECM. Though if you have a relatively good understanding
of mid to lat 80's auto tech, it's easy to tweak them.
It's the new shit I dislike, I-phone on wheels type, let the sky-net have ultimate control
over your new computer on wheels.
PostPosted: Thu Nov 17, 2016 6:38 am
I do not have that seal on mine. I would run a bead of silacone around mine but had no idea there was a gasket intended for it.
The one I saw on eBay was a base gasket like you would find on a Chevy V8,I'll see if I can find it again.
