I bought this silicone hose a few years back, it has worked well for me. This seller had it in other colors
in 5/16, but now only black, plenty of other sellers with other colors now.
Do not use worm drive clamps, you must use spring clamps, or better yet fuel injection clamps.
Use a wobble socket on a locking 1/4 drive handle to tighten the FI clamps, or a standard socket
on a flex shaft 1/4 " drive handle works well also.
#33 is a bitch, but if you get a pry bar in there you can bend the coolant pipe on the turbo slightly
for a little more room for the clamp, I learned this much later. Also the newer X-type high leverage
long handle needlenose from gearwrench or crescent with the 45° angled jaws make removing the
spring clamps much easier, as less movement is required to open the jaws fully than with standard
type handles without the X-mechanism.
You can delete #28 as well and use one piece hose for #32 for simplicity. Use a hose guard
protector in places where it may chafe. Hose is robust and sturdy and stays flexible and supple, though colored
hose will fade with time and temperature. It is not however, resistant to sharp edges, protect
it in areas prone to rubbing or scuffing.
Best of luck.
