It is currently Thu Nov 23, 2017 3:37 pm
PostPosted: Fri Jan 29, 2016 12:45 am
Has anybody used an electric fuel pump in there Sprint/Swift, 1.0 3 cylinder. My fuel pump is a 3 line one . My manual fuel pump shaft has frozen in place.
Rockauto has one for $23.79.
AIRTEX E8016S
Electric Pump; Solenoid;12 volts; 2.5-4.5 PSI; 30 GHP; 5/16 hose; Import Passenger and Light Truck Carb One of our most popular parts
May Be Used As Replacement For 3 Line Mechanical Fuel Pump
Thanks for any help
Also if anyone has the current Rock Auto discount code
Dale
1985 Chevy Sprint Mk1 G10 5 Speed Sky Blue
PostPosted: Mon Feb 08, 2016 9:06 pm
viewtopic.php?f=31&t=56297&p=422812&hilit=airtex#p422812
You may want to read my past post about airtex pumps. Now the above is mostly about mechanical but I also went through similar with electrical. If you choose to run a electric try anything but Airtex, and most part houses have others. You will also more than likely need to install a regulator, even most mechanical pumps sold now for Sprint applications put out too much pressure.
Mike
Valley Grande, AL
1986 Sprint plus
Do you maintain a personal fleet like I do?
Why do we do it?
Because it's what we enjoy and because we CAN.
2011 camaro, 2005 Vibe, 2016 Outback, 06 Expedition, 87 Porsche 911, 87 Turbo sprint, 82 Brat, 73 gmc 4x4, 69 camaro, 99 Gl1500 Honda Goldwing, 12 Kawasaki klr650, 2012 Kubota L3200, and we wont even go into the small stuff.
PostPosted: Mon Feb 08, 2016 10:07 pm
Thank you very much for the feedback. I will take your advice..... :D :D :D :D :D
Dale
PostPosted: Wed Feb 10, 2016 2:54 am
i was getting a needle flutter from 4-6 psi at idle and closer to 6 at high rpms.
the 86 sprint has a fuel cup in the gas tank for the uptake tube, i wonder how much they changed the fuel tank design from the mk1 to the mk2. ive been wanting to convert to a eletric fuel pump. i wonder if the intake fuel pump from the mk2 will mate up to the mk1. i got a clone bosch 044 inline fuel pump waiting to be put on, but mounting it is a problem. id have to mount in the engine bay, and im not sure how long it will last going from a 6 foot 1/4 inch intake to a 5/8 intake at the pump, then back down to 1/4. the only real option is see is to buy a mk1 geo metro 2 door fuel tank and see if it mates up, or take a risk and buy just the intank EFI assembly.
-vernon wasser-
88 sprint, 4dr sold :(
87 turbo 2dr, never ran :( :(
86 sprint, 2dr current DD! :)
