evilhighway wrote:
What is the grind motor sobil?
I'd say autocorrect strikes again - maybe should have said GTi engine. If you find a GTI engine and close ratio gearbox ...... Keep the car they are in and build it instead.
New springs, an extra leaf or helper springs might tune up the backend. Not much else you can do.
I thought snowmobiles use two strokes engines. If the carbs are off a 'stroker, they will have different slide cutaway, jets, needles and maybe emultion tubes (which could explain your mixture). All easy enough to change if you have access to enough bits. Might also have an oil injection port you would have to block off. Old School Bike shop should be able to sort the carbs out. Been through seting up VM30 Mikuni's on a bike.
With the timing, I'd guess the ignition's all standard so nothing unusual. Best you can do without modifying the dissy is set the maximum advance to what you want and put up with where base advance starts. You should be able to set 34 max and 14 start or close to it. Set the maximum advance at the revs you want (you need a timing light that has an adjustment on it to dial in your maximum advance and it will show as zero on the timing marks when you turn the dissy to 34 degrees) and then see how much base you have.
Start at 32 degrees at 4000 and see how it goes. Then have a look at 34 / 4000. I wouldn't go past 34 degrees unless you're on a dyno. Even then, unlikely more advance is going to do much without a lot of other changes to the engine.
Jaycar sell a programable ignition kit that allows electronic programing of your ignition curve. It's a kit you have to assemble.
Once you start squirting NO2 into it - engine won't last long. The G13BA engines (crank and bearings in particular) were never designed to make any real power - about 50 HP if you're lucky.
MK1 GTi has a different bottom end, fuel injection and starts at 100 HP at the flywheel. Couple that to the close ratio gearbox and you have a completly different beast. What you have is fun till you push it too far then it's rebuild time. For what it's worth, might be better leaving this car where it is (the development of it) and finding a Mk1 GTi to build up or transplant the GTi running gear into your current shell. GTi transplant means you still have the leaf spring rear to sort out.
