It is currently Thu Nov 23, 2017 1:13 pm
PostPosted: Mon Aug 07, 2017 2:29 am
So, I have gathered most of the rear wiper components for my car. (Rear wiper arm, motor, switch, glass and harness) I still need the dual pump reservoir for under the hood. My question is this: If my car lacked a rear wiper from the factory, should the wiring harness for the rear washer be under my hood? I know I needed the rear wiper harness and have that. Just don't know if I need to pick up anything to connect up the 2nd washer motor (which I do need still). Being overseas, I don't have my car with me to look myself. Thanks in advance.
'94 Metro LSi 'Green Machine'
'94 RHD (Totaled)
Vail, AZ
PostPosted: Tue Aug 08, 2017 3:08 am
I am 100% sure that Geo Metro has everything (both main harness and reservoir) so you only need to install rear wiper assemble parts and switchers.... just plug and play.
I did check my based trim MK3 Swift GA that contains everything except switchers and rear wiper assemble parts. Therefore I am not too sure about MK2 and or Geo metro but they should be... Pretty easy to check... check for spare connectors and matched wires.
sorry bout my bad english
PostPosted: Tue Aug 08, 2017 2:00 pm
there should be an extra/rear pump plug-in wire attached to the front pump wiring harness. the plastic tubing should be there as well. at least it is there on my 92 metro......
