I am building/modifying a stock G10 harness. I have found the Metro harness I got from Pick a Part has small insolation breaks just at the connector exit. Has anyone found a source to the ECM connector receptacles? Also if anyone has extracted these receptacles I could use some pointers on a tool and the easiest way to pull them out. The factory manual does not cover the ECM connectors. I have modified many Honda harness with no problem. The Suzuki is completely different having a strain relief built in as well as receptacle retainer. Or I have lost my touch.
The G10 is going into a 1971 Honda N600.
_________________ 1971 Honda N600 Transplant w/ Suzuki G10 engine and 5 speed trans
