OK here's one for everybody who wants to run an aftermarket ECU but has the same old problem with the non-standard suzuki dizzy.
I spent a couple of hours sifting thru two pellets of distributors until I found this one, it's off a toyota cynos, 4afe? it's also the same as 4age dizzies apparently. The engagement tooth fits perfectly into the end of the cam, the only difference is the shaft is longer than the suzuki one, so you can use the whole distributor without modification with a suitable adapter.
This dizzy has 3 pickups, 24 teeth on the top wheel and 2 on each of the lower wheels so I can run sequential injection with my microtech.
Since I'm running quad coils I don't need the rotor so we machined the top off the dizzy cap.
