It is currently Thu Nov 23, 2017 8:16 pm
Post new topic Reply to topic  [ 1 post ]
 Post subject: Useing GTI Front End
PostPosted: Sat Apr 29, 2017 11:23 am
I have an 89 GTI parts car, complete.
I need to know on the front end, the spline dia and count?
But also would want to know if the front hub itself without the CV shaft locked tight with the nut, hold up?
OK here is what Im doing!
I have a Suzuki Cary Truck!
I want to use the brakes and struts and control arms and put it in this truck!
And its 4 wheel drive!
If I have to I could take both half shafts in and have them made?
But the truck is weird the only thing holding the splines of the CV shaft is just a cover plate that goes over the lugs!
So I could make a sleeve to get the shaft through or have a CV shaft made?
